View Full Version : Replacing a powerglide
gtome
10-05-2005, 09:23 AM
Does anyone know what tranny's are the same physical length as a 2 speed glide? I would like to replace it with a T-350/400 or OD trans.
Thanks!!
derekf
10-05-2005, 09:25 AM
TH350 should be the same length and same mount points.
cad
10-05-2005, 04:46 PM
th350 was a direct bolt in for my 68 Camaro.
10-05-2005, 10:40 PM
If this is for your BOP, 400's are alot easier to find...ask me how I know! LOL
A 350 would be an easier swap but...
There are another set of bolt holes to mount your trans crossmember back farther.You'll need to get a shorter drive shaft and mount and wire in a kick down switch. We had an easy swap cause we found a donor car in the wrecking yard.
indyjps
10-05-2005, 11:50 PM
what kind of shifter are you going to use, ive got a horseshoe shifter that was used in a p/glide to th350 swap, you just have to notch out a section to get to 1st gear. pm me if you want pics.
gtome
10-07-2005, 04:56 AM
My shifter is a column shift. If I have to do some mods, I may just go with an OD trans to make it worth my time and money. Is there an OD that would be a bolt in without much mods?
djmd72
05-02-2007, 05:46 PM
411 from the interweb:
"The 200-4R overdrive trans has a 27-spline TH-350-style output shaft and is commonly found in ’81-’90 Chevy Monte Carlos, Malibus, El Caminos and Impalas. These transmissions are durable enough to withstand the punishment of the legendary turbo Buick Grand National from the factory. The 200-4R measures 27.75 inches, with a 26.81-inch mount position. To swap with the ’Glide, the crossmember must be moved back 6 inches. The good news is that the driveshaft will not have to be shortened."
http://www.drwtransmission.com/thm_200-4r.htm
zbugger
05-02-2007, 06:44 PM
Yup. The 200-4R is the same length. I used the same driveshaft with no modifications when I swapped it in for my th350. The mount is quite a bit further back though.
