toofun
09-13-2005, 04:13 AM
I was reading an article called The Numbers Game in CHP Aug. 2002 It was talking about gear ratios and how they affect performance. They say that the optimal Final Gear Ratio for a street car is around 10:1. I realize that if you multiply the first gear ratio by the rear gear ratio you can get your final gear ratio, BUT they say things like tire diameter and the torque converter have an effect on it as well. I am trying to find the best rear gears to run for my application.
I have a small block chevy that duplicated the GOODWRENCH QUEST motor CHP built. I currently have a 2400 stall converter in a th-350 with 3.42 rear gears. My wheels are 26.8 inches tall. What would my final gear ratio be with this application given that I have the tires and converter I have. Also, what would be the optimum gears to run for the street with this application? I also am thinking of running a 200r4 or a 700r4 OD tranny for this car as well so any input on what gear I should run with that would be helpful as well. Sorry so long but trying to be thorough.
Thanks in advance
Mark
TOOFUN
Thanks in advance
Mark
TOOFUN
