View Full Version : Stock swaybar with Tru-Turn
Ryanater
10-07-2013, 10:33 PM
Has anybody had experience on how much turning radius is lost when using a stock style swaybar with the tru-turn system? Assuming a 275mm tire. Is it still pretty driveable?
Garymac69
10-08-2013, 08:22 AM
I still have a stock style sway bar and had to limit turning radius some....probably 10 to 15%....to prevent the bar rubbing the inside lip of the wheel at full lock. I notice it when making tight turns in parking lots. I plan to get a front Musclebar when funds permit.
Ryanater
10-08-2013, 08:33 AM
So it's not a huge deal? It sounds like something I could live with for a few years.
Ryanater
10-08-2013, 08:44 AM
Also, what bar do you have? I'm running an Addco bar.
brownz
10-08-2013, 03:07 PM
I have a solid big sway bar on the front of my 72 nova. I do not know the manufacture on it but my tires will run frame before the bar. Im also running stock lowers so the bump stops dont match up with the spindles. I hope to get time to fab up some or get ride tech arms ONE day.
what backspace are you running on the front wheels?
Ryanater
10-08-2013, 03:17 PM
What size tire are you running? Any chance you could get some pictures?
I am running a 9.5" x 17" Z06 wheel. I'm not sure what the backspacing is but I will need to run a spacer.
Garymac69
10-09-2013, 08:13 AM
I also have the Addco bar and have been using it for about 3000 miles or so.
Rod
10-09-2013, 10:53 AM
usually the tire contacts the frame before the sway bar comes into play, my experience using both a Helwig sway bar and then a Hotchkis sway bar the rim never touched them, but the ridetech muscle bar contacts about the same time as the frame and works just fine
brownz
10-09-2013, 05:08 PM
I will be getting the car out tomorrow and will try to get a pic. Im running a 255 tire on a 18x9.5 wheel with 5.75 bs. I will be putting 275s on in a week. but still the tire hits the frame before the bar.
