View Full Version : The LSX Forum
Pages :
1
2
3
4
5
6
7
8
9
10]
11
12
13
- victor junior on 69 camaro
- Any GMPP reps on here
- which headers fit
- 1986 Elcamino 480HP LS looking for the best solution for front accessory
- fuel line ? size and material suggestions? ls7
- 2nd Gen Camaro LS Build
- E-Force LS7 Dyno run & Final Numbers
- IN STOCK! Rick's Stamped Steel 67-69 Camaro / 68-74 Nova EFI Gas Tanks
- Smaller p/s pulley Holley accessory drive, headers ls 71 nova
- '71 Chevelle LS3 Header advice!!! Please
- LS3 with no throttle response
- need cam help LS 444cid build
- Speed master starter
- ZL1/LSA Info needed
- LS3 fuel rail removal
- x pipe for ls7 in second gen camaro
- Ricks (Resto Mod) new EFI fuel tank
- LS7 Hard Start
- Valley pan question
- Accessory drive for LS motors (cost effective)
- holley harness and painless universal harness wiring question
- clutch?
- Solid Engine mounts for Lq4 engine
- LS2 / L3 heads comp cam. DOD question
- LS7 Card style MAF placement
- LS1 fuel injection vs carb?
- LS swaps in Bay Area/Nor Cal?
- 5.3L turbo/zor 6.2L all engine
- First gen f body, what motor plates w/ stock oil pan
- cam swap
- Entropy Radiators now available from MCB!
- Autokraft Oil Pan Dealers
- GM Performance LS3 ERod P2135 code won't run
- ls7 fuel filter/regulator location ?
- 2014 Camaro SS swap into 1968 camaro
- LS3 Engine doesnt start after sitting
- LS Oil pans for 4" + sized crank shafts
- l92 injectors fit ls3 intake.
- Looking for tuner in southern Wisconsin or northern Illinois
- 69 Camaro Ls3/ subframe swap question
- Thickness of Speedtech/ATS adapter plates?
- LS Pedal Assembly
- ls3 vs ls7
- holley ls trans cross member
- LS7 in a 66 chevelle. Modifying the crossmember...
- Project Dirty Bird
- Spanky's Rod Shop LS3 Cruise Control
- Dakota Digital Water Temp Sender
- 68 Firebird/LS2/TKO 600/ engine mounts on stock subframe
- Coil covers
- Auto trans wont shift after ls1 install
- 5.3 Vortec price question
- ls3 water pump
- Anyone use 98-02 LS1 radiator in 1st gen swap
- LS bracket question
- LSA supercharger: Put it on a stroker LS3 or a stroker LS2
- Mast LS7 SS 675hp Aggressive Street Usage?
- Will stock exhaust manifolds work, ls3/camaro
- Ls2 question
- Help me build my 5.3 Vortec
- Need HELP IAT wiring
- Fuel line question
- Ls motor mounts that dont vibrate
- Lsx 454r
- 76mm turbo lq4 69 Camaro
- LS in 66 mustang coupe
- LS3 and Vintage air
- vacuum line routing LS2
- 67-69 Camaro header question with 6 bolt heads?
- LS Vintage Air Power Steering Pump
- Idiot Lights
- Steering box options with an LS swap.
- LS headers for 2nd gen Firebird
- LS swap into '94 Trans-AM
- sstb ls2 intake clearance
- Knock sensor
- Thoughts on 8000 RPM LS build article in HOT ROD online?
- chevelle LS swap questions
- Is this going to melt?
- 67 Camaro Best fit Intercooler LS SWAP Turbo
- People with running LS3/525HP swaps...come on in...
- CHE Bushed Rocker Arms
- 5.3 LS1 swap 2nd gen Camaro
- throttle cable for 69 camaro with ls1
- 15' "LT-1" vs "LSx" swap...
- Need HP Tuners help
- Need some help..
- LS3 vs LSX vs Pontiac motor swap ?
- LS swap 68-72 GM A body. radiator hose help
- MAF cause engine to not start?
- Which brake pedal to use with 1967 camaro LS t56 swap?
- ls9 dry sump
- LQ4 starting issues in donor vehicle
- Stalling When Hot
- LSx Swap pitfalls
- Priming dry sumped ls3
- Built LS3 - use Warren PCM & cable throttle or DBW setup??
- adjusting LS3 idle speed
- Low Fuel pressure external electric fuel pump help!
- stack style intake manifold, which one works the best?
- Ls1 in 65 GTO clutch pedal rod
- drive by wire or cable throttle on LSX454 with Jenvey cross ram
- ls3 swap in 69 camaro
- Best oil pan for lex 454 in 67 camaro
- siphon fuel pump
- best LSX 454 wet sump oil pan???
- 1981 Trans Am LS1 swap / donor car
- Fuel Pressure
- C7 LT1 Engine 69 Camaro
- A body, center the engine/ trans in the frame rails, or trans tunnel?
- LSA supercharger on l92
- LSX 454, 2inch or 1&7/8 headers
- LS3, GMPP harness fly by wire pedal swap
- New custom welded CAI ... Titanium
- fuel system help for boosted L92?
- LS engine does not fit in 1969 Nova
- gpmm ls3 controller help
- LSX 454 throttle body touching the water pump
- HP Tuners file needed
- Roto-Fab LS1 LS2 LS3 goodies
- LS 71 chevelle swap, input needed
- IROC Box with LQ4 Swap in 69 Camaro
- MAST Motorsports ECU situation
- LT4 Supercharged Crate Engines Now Available
- Need swivel or down facing Thermostat housing for LSA.
- Power steering cooler and engine oil cooler sizing
- Trans temp sender Moved to trans setion
- Advice please
- Crate LS3 options
- Comp cam ?
- Anyone running Holley Terminator TBI on an LS yet?
- Wiring... for the entire car in one shot (?)
- LH6 & LM7 Interchangability
- Ls3/6L80e into a 1979 or 1968 camaro.
- mast motor questions!!
- opinions on a LS flash programmer
- Good place to buy drop out engine?
- Coil fitment with Holley LS tall valve covers
- E-Rod LS3 Emissions Question
- Need help with my LS376/480 project!
- LS Swap in 1970 Z28
- Drive by wire pedal, computer, throttle body compatability Please help!
- bullet proof engine
- Looking for proven LS swap kit for Ridetech tru turn
- What engine mounts to use for a 1969 Camaro LS swap with Holley parts?
- Injectors not pulsing..need help
- Examples of wiring harness installs and fuse box locations; maybe some pics please?
- Ls7 factory pedal bracket?
- Pcv related issue
- Low budget LS swap
- ls2 swap starting issues
- cam swap ls3
- wire harness/computer options for LS swap?
- New Trunnion Upgrade
- LQ4 intake on L92/LS3 Heads?
- LS3 525 hp bell housing
- 72 chevelle LS swap
- Airaiid U Build It 100-400 Tubing kit?
- LS1 shuts off under hard braking
- LS Fuel rail covers
- LS2 intake manifold
- FAST LSX R 102 intake whistle....anyone else?
- ls3 6l80e swap question about tunnel 69 Chevelle
- Dakota Digital VHX with BIM 13-2 Wideband and Innovate Motorsports (3877) LC-2
- unique vats bypass question
- Throttle will not respond after tune
- Attractive drive/accessory system without AC that I can add later
- Any reason (other than price) not to do a Ron Davis rad setup?
- Best intake for LS6 for street use ?
- LS2 tune question
- LS Swap, engine runs 30 sec and dies. PLEASE HELP!!
- 1966 Chevelle LS3 engine swap with 5L40-E automatic transmission
- LS3 Radiator sizes
- 69 camaro ls swap. looking for specific size header
- New LS3 Dyno numbers
- Cold air intake question
- Edelbrock E-force Supercharger LS3
- Which ATI balancer for a LS3 in a 69 camaro
- Computer programmer/tech Dallas/ft worth area
- LSA Swap - A/C Question
- Data logger/tuner help ls3
- LQ4 Swap to 69 Camaro PS Pump?
- LS3 durability on a reasonable budget
- Best LSX hi torque mini starter
- LS3 no oil pressure during priming
- Anyone have any idea on LSx in a 1970/69 Mustang
- Flywheel question
- best progressive release clutch
- Holley Terminator LS Kit..anyone using it?
- Supercharger and VA frontruuner
- Anyone know what air intake kit this is?
- Chevelle Resto Mod lq4 6.0 to 408 ctsv/zl1 supercharger work well?
- LS3 dead throttle (drive by wire)
- help-97 LS1 PCV connector to drivers valve cover
- 1st build 63 NOVA twin turbo
- LS Swap Kit for a Pontiac B-Body?
- LQ9 instal into 2nd Gen Firebird
- Is this pedal part available seperately? GM Perfromance pedal.
- Oil pan to cross member clearance
- LS Header Gaskets
- engine pull tips/tricks
- Crate Engine vs Building?
- Mounting LS7 oil tank in sec gen camaro?
- LS6 to LS7 conversion
- 69 camaro ls3 header help!!!??
- Corvette filter/regulator bad for Aeromotive pumps?
- width modulated fuel pump
- LS7 cylinder head re-work service
- Lsa accessory drive
- Another engine mount question..
- L99 / 6L80e take out questions
- Holley LS Conversion fitment issue (maybe)
- LS2 Swap fires and dies need help.....
- c6 DBW pedal mount for70-81 Camaro
- LS7 Maf where to mount. pics inside please help
- Mast M90 w 6l80
- valley cover bolts with lift plate
- pic of my 68 Camaro LS1 swap
- 67 Camaro Frame Mounts
- LH6 dod and afm lifter issues
- Deleting both sets of O2 sensors?
- Speartech LSA Wiring Harness and Monte Carlo Pedal
- FAST EZ EFI LS with XIM and TCU
- ls turbo and air conditioning
- Holley HP efi LS1 running issues
- Low Mounted AC with SpeedTech Subframe?
- LQ9 w/ 317 heads Intake Manifold Upgrade Without Swapping Heads?
- Measurement please LS376/525
- changing fly wheel
- 2014 L99 6.0 with VVT. Is T56 not a good choice? Auto better?
- Pace Performance
- 68 Camaro Convertible LS1 Swap
- atk built 408 rod bearing failure👎
- Ls1 swap
- LS3 swap into 72' Camaro questions
- 2013 camaro tac module?
- Oil loss
- Heater and Ac hose routing
- holley terminator v. holley hp efi
- dry sump tank question
- Looking for a place to mount my catch can
- Will a LS1 radiator with an LS2?
- RX Catch can routing with whipple
- LT1/LT4 Stainless Steel Headers for Art Morrison Chassis****The Eagle Has Landed*****
- Alternator wiring
- LS PCM power connection
- Help me choose an LS. I have 3 available options
- Autokraft pan and oil filter adapter
- 08-09 Tahoe 6.0 good or bad engine. Help please
- Ground Straps
