View Full Version : Disc Brakes
Pages : [1] 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17
  1. Cool! First post in this section!
  2. A-body drum to C5 disc
  3. braided brake lines worth it?
  4. 4 wheel disc brake conversion ?'s
  5. Driveshaft or Pinion Mounted Parking (Emergency) Brake System...
  6. power brakes
  7. What happened to www.touringcamaro.com
  8. Is it me or did my BAER kit come half complete?
  9. rear disks and C-clip eliminator
  10. LS1's on drum spindle
  11. Help w/Prop Valve
  12. What size and back spacing will I need to clear Baer's?
  13. Linkage...help, Power Booster
  14. Track width difference w/ Baer brakes on 69 Camaro
  15. LS1 fronts with drum rear, questions???
  16. I'm stuck...discs for my '68 camaro
  17. ECI brakes
  18. rear disk
  19. Spindle or NO Spindle
  20. Wilwood brakes squeeeeeeel like crazy!!!
  21. Need junction & master cylinder
  22. New Baer Brakes!
  23. Need some help with a 65 coupe
  24. rubbin'
  25. 3rd gen camaro rear disc brakes on 70 chevelle
  26. pics rear brakes?
  27. Brake bleeding
  28. caliper shoot-out?
  29. M/C for C5 calipers on A-body?
  30. Hydroboost??????
  31. Front/rear disk brake sizing and calipers?
  32. Corvette C-4 Brakes on a 1st Gen...
  33. hydratech bleeding
  34. Thoughts on this master cylinder..
  35. Leaking Prop Valve and Tuning?
  36. Feedback Precision Brakes Company
  37. Aluminum hubs??
  38. Running brake lines
  39. Whoa!!!
  40. Who on this board used a 92 Corvette master cylinder?
  41. Low pedal after disc conversion...? HELP!
  42. How long to install baer brakes at all 4 wheels?
  43. JMC dual master cylinder ?
  44. help!!! cant get spindle off!!
  45. c5 caliper question
  46. Another C5/A body Question
  47. Touring Classics Hybrid Kit
  48. Impala SS front calipers
  49. will s10 brake
  50. Late F body (LS1) rear disc on 1st gen F body
  51. read this!
  52. Not trying to stir the pot
  53. Multple forums same cry for help!
  54. Question about big calipers and braking pressure.
  55. HELP! anyone know the difference between REAR C5 and LS1 caliper brackets?
  56. Baer Brakes Serious Street?
  57. Rear Brake Hardlines
  58. disc brakes fro '77 to '68 ????????
  59. looking for a 69 Rear Disk setup
  60. Baer online info
  61. C5 2nd Generation Brackets
  62. Is it worth it? Stock size slotted rotors.
  63. C5 master cylinder
  64. LS1 Rear Brackets
  65. Rear Brake swap
  66. Question about Baer Brakes
  67. Baer Brakes for old Fords?
  68. Master Cylinder Question
  69. Opinions on Brake set-up
  70. C5 Conversion Hub Balance Question
  71. mustang......
  72. Emergency/Park Brake
  73. C5 park brake parts?
  74. Which rotor and MC to use with LS1 calipers
  75. Vibration when braking from high speeds
  76. New Touring-Classics front/rear discs
  77. have 12 bolt need brakes 72 chevelle wagon
  78. Upgrade options for front brakes on 2nd Gen. Camaro
  79. Which Years LS1 Rear Brakes Fit a First Gen Camaro
  80. Adjusting problem ?
  81. What wheels work with the C5 rotor?
  82. ford 9" disc brakes
  83. Crossdrilled rotors part 3!!!
  84. Front Disc Question.......
  85. Torque Specs
  86. Corvette or Camaro ABS Swap into my 69
  87. New cheap big brake idea
  88. Partitioning valve bracket
  89. late model camaro rotor differences??
  90. Need assistance.
  91. Painted calipers - yes or no?
  92. Touring Classics C5 conversion & dropped spindles
  93. Any issues with Durastop rotors?
  94. Who makes mounting brackets for C5 brake swap?
  95. C5 brakes on 2ndGen Camaro?
  96. Partial C5 brake swap
  97. Master Cylinder (for JL8 brakes)
  98. Malitude master cylinder ?
  99. cheap front disks for 62
  100. Bias Bar vs. Prop Valve
  101. Rotor diameter ?
  102. Master Cylinder question for PBR calipers
  103. Mule Master Cylinder?
  104. Christmas Sale at Touring Classics
  105. 13" Rotors on C4 Rear ???
  106. funny cross drilled post from ls1tech .com
  107. are compression fittings ok for brake lines?
  108. 15/16 master on C5 front brakes?
  109. 4th gen booster in a 1st gen f body
  110. C5 rear brakes on Buick GN?
  111. Opinions on floating rotors?
  112. Baer Track 13 on 79 Trans Am
  113. Double-check my braking plan
  114. rear disks?
  115. cheap? early vette 4piston to 1st generation
  116. Disc Brake conversion - which one??
  117. Wilwood brakes on Chevelle
  118. Good place to buy PBR calipers
  119. Brakes for Ford 9"
  120. Is there such a thing as too much brakes?
  121. Piston sizing...
  122. Question about C5 calipers
  123. Pressing studs from drum hubs...Help.
  124. Drum Brake hub source
  125. no emergency brake
  126. 2piece Drum Hub Vs Drum Brake Hub Sizes?
  127. Not disks but drums
  128. 4th gen master on 2nd gen F-body
  129. Beating a dead horse.
  130. C5 brake brackets, where???
  131. Booster Confusion!
  132. 4th gen camaro mc throw?
  133. Dropped A-Body Disk Brake Conversion
  134. Need advice on brake purchase
  135. #5460346 Master Cylinder
  136. Rear Disk for 77 Trans-am
  137. Aftermarket Direct Replacement Calipers 67 Camaro
  138. erotorshop on ebay
  139. Need Help with Front Disc Brake Kit for 17x8.5 Wheel
  140. Largest 12 bolt disc?
  141. what other drum hubs?
  142. C4 calipers at Touring Classics
  143. Backing Plate with Aftermarket Discs
  144. Affordable front and rear disk brakes for 69 Camaro?
  145. Master Cylinder questions, disc/drum, disc/disc. Pushrod?
  146. MC for C4 swap
  147. parking brake clearance problem
  148. 4th gen Camaro master hook up
  149. WS6 Brakes vs. LT1 brakes
  150. Wilwood Kit
  151. Need Dimension Caliper/Caliper Bracket
  152. hydro boost questions
  153. Brake Booster?
  154. Caliper Finishes?
  155. Baer 79 Firebird
  156. Rear Disk brake brackets/baskets
  157. will this Idea work???
  158. rear disk brake offset on 69
  159. ws6 ta brakes & mc choices
  160. Willwood Master cylinder
  161. 69-82 Corvette
  162. 4th gen MC bore sizes?
  163. 2nd Gen. Factory rear disc brakes
  164. LS1 Rear Brake Part Numbers
  165. Lincoln LSC 8.8 with discs, how wide??
  166. Best Baer Brake prices?
  167. C5 Brakes, Manual M/C, Pads?
  168. Looking for CBB for corvair
  169. baer trac question
  170. rear disc caliper location
  171. Baer Brakes prices
  172. Road race brakes & future upgrades
  173. Wilwood rotors: cracked
  174. Dirveshaft parking brake
  175. Custom Wilwood Brakes
  176. Road race brakes, my plans
  177. Holy Sh!^$*&^!!!
  178. Low Budget
  179. Question for Paul@Hydroboost
  180. C5 to 1st Gen Swap Hub problem --- What's all the hubbub, bub?
  181. Slotted rotor mounting ??
  182. Using Compression Fittings on Brake Lines
  183. Looks like I may have a rear disc problem.
  184. S10 M/C Bleeding Tips?
  185. C5 rear caliper questions
  186. Booster Big to Small
  187. C5 Swap Master Cylinder Options - Manual vs Power
  188. swapable rear ends
  189. Dust Caps
  190. PBR cobra calipers = Baer pbr calipers?????
  191. brake question
  192. Need Help With G-Body
  193. Long pedal with Cadillac callipers
  194. factory swap
  195. Brake companant question, brass metering block?
  196. Best front brake lines?
  197. C4 13" brackets
  198. disc brakes for 12 bolt
  199. m/c question
  200. rear axle hub diameter/C5 rotors
  201. C4 and/or C5 bearing pack dimensions
  202. Rod between booster & master cyl
  203. drum to disc conversion cheap!!!
  204. 1st gen drum hub on 2nd gen spindle
  205. Which master cylinder? Pushrod length?
  206. 12'' c4 brackets
  207. Another C5 Brake Question -Master Cylinder
  208. how do i switch from manual to power
  209. C5 Brake Adapters for 2nd Gen needed
  210. wheel stud lengths when changing to rear disks
  211. '64 Impala Disc/Drum MC Advice
  212. Brake Fluid question
  213. Difference between LS1 calipers and C5 calipers?
  214. Who are the best providers for Dana 60 Disc conversions
  215. Cooling ducts for front discs
  216. need rotors for 7? trans am rear
  217. Wilwood vs. Baer
  218. Wilwood master
  219. Baer disc brake squeeking, how do you get rid of it?
  220. Permanently Mounted Brake Pressure Gauge
  221. Needing a Power Booster
  222. What manual master for LT1 rear disks in 2nd gen Camaro?
  223. symptoms for too small master????
  224. symptoms for too small master????
  225. Baer's new 6 piston caliper ?
  226. LS1 Rear Discs on an A-Body
  227. baer vs Wilwood
  228. which brake fluid?
  229. Braking questions
  230. 2nd gen front discs on 68 GTO
  231. Parking Brake for Wilwood
  232. Power to Man. 79' Firebird (Help)?
  233. 2nd thoughts on Baer brake system
  234. SSBC rear discs for 2nd Gen Camaro
  235. Rear stainless steel braided brake line - Flex hose
  236. Concerned about my new Wilwood's
  237. brake comparo - what brands are good?
  238. What setup to use with 15" rims
  239. 69 Camaro Rear Disc's
  240. brake pedal stays down?
  241. 4th gen rears done but ?
  242. Yet another 2nd Gen Camaro, "TorkersCamaro" C4 rear brake ?
  243. big brake and rear disc upgrade
  244. Brake Booster action
  245. baers on 12 bolt rear
  246. Braided lines LS1 calipers and first gen
  247. Wilwood brake help
  248. What to use?
  249. Whats the best way to go about big brakes ???
  250. adjusting rear brake bias
