- Porsche Brake Conversion
- Need help with Corvette IRS
- 93 camaro front brakes on a 67
- LT1 or LS1 brakes...
- SSBC or Baer for my 55 ?
- Disc brakes on 9" in 69 Camaro?
- New "Big Brake" kits from OPG - any info?
- C3 master cylinder hookup
- C4 caliper to abutement bracket
- LS1 to drum spindle bracket
- Which master cylinder
- best prices on c5 calipers
- Wilwoods on the way from Precision Brakes
- caliper bore size ?
- Baer has a new site
- Baer Brakes Price???????????
- dynalite brake pads
- Soft brake pedal problem - new 4-wheel manual discs
- g-body/s-10 front pad upgrade
- rotor question
- LS1 Brakes 12" rotor?
- Power to manual conversion - Does adpater plate affect pushrod length?
- Baer brake kit for Mopar
- C5 rear information
- c-5 fronts what ars they worth?
- Painted Rotors - the wheel to rotor mating surface - bad idea?
- Brake conversion question
- Disk brake conversion
- 70s vette 12'' rotor offset
- Need some newb advice on an unusual combo
- Caliper adaptor bracket for LS1 and C4 13" the same?
- corvette spindle
- disc brake spindle and 4th gen brakes
- best brake pad material
- Stock 68 4 piston caliper
- power or manual set up with wilwoods??
- 2nd gen cbb
- 4 wheel disc setup
- Does anyone understand Master Clyinders???
- New CPP Master Clylinder
- Bear Brakes
- C5 vs. LS1 rear components
- brake booster
- who has completed the 1st gen to LS1 front brake swap? need help and parts
- wilwood master
- Another ls1 question.
- c4 conversion master cylinder on a 69 camaro
- 4th gen LS1 rear disc to early f-body swap........anyone pull it off yet?
- C4 or C5 Conversion
- offset on 12-bolt
- 4th gen rear adjustment?
- lt1 or ls1 rear disc
- C5 brackets
- Brake donor
- rear lines
- C5 brake/wheel fitment question
- Hard Brake Lines - Double Flare Issues
- master cylinder for ls1 brakes
- Baer Serious Street Package
- 1" bore master
- LS1 Rear Calipers were good, now Shot??!!
- 73 firebird rear brake conversion ???help!!!
- URGENT: I just CANT get my car to stop!
- The Mule's MC?
- power or manual
- Loosing pedal at low speeds
- max line pressure
- Installing 3rd Gen rears on a 12 Bolt
- wilwood versus baer
- rear brakes bigger than front?
- proportioning valve?
- Wheel relocation with disks?
- C5 rear disc brakes on 2nd gen Camaro
- c5 manual master clyinder?
- C5 or C4 disc??
- Drop spindles using stock application discs?
- Wilwood Brakes on the way! Thanks!
- Wilwood 4 vs 6 piston front brakes
- Firebird louvers converted to brake ducts
- Painting rusty rotors
- Who Sells Wilwood
- #*$*#@@# Brake lines keep slipping out of my flaring clamp!
- How do I install Bendix Hydro/Boost to GM steering gear
- master cylinder for wilwood
- 6 Piston Vette Brake Kit Nearly Complete-Finally!
- Replacement rotor source(s)
- cheap rear disc setup for cheby
- Bigger disc brakes and spindles
- Cleaning rotors for painting
- Wilwood Truck kits? New
- C5's on a 3rd gen?
- Thanks Pro-Touring (Wilwood)
- Front Brake Hard Lines - what to do
- G-Body Brake Upgrade Question....
- 68 Camaro disc convert
- Hydroboost Questions
- Master Cylinder for c5 brakes
- 11 inch drum upgrade from MASTER BRAKES
- Rear disc conversion question
- Please help, I need advice
- Combination valve ??'s
- Speed Bleeders
- JL8 parking brake
- Wilwood vs SSBC Disc Brake Conversion?
- Noob question
- 2nd gen brake kits?
- Achieving proper brake balance
- Power Vs Manual Brakes (4 wheel disc conv)
- Best Brake pads for C5 calipers? less dusting, best braking?
- Dot3 or Dot4
- Manual Brake users??? Mr. Pozzi
- brake cooling ducts
- What Disc Brake Upgrades fit 15x8 Rally wheels
- 69 Camaro with LS1 Calipers Brake hose Connection Questions
- Help! Brakes won't bleed all the way, C5/LS1
- Brake Lines Suck!!
- Which Master Cylinder for my manual disc setup
- 4 wheel disc brake conversion for a 1970 mustang
- How long should my wheelstuds be?
- Spindles
- Where to get drum spindles and zinc washed rotors?
- C5 Brakes PLEASE help!!
- C5 brakes and TTII's
- Checkout my new Brake setup
- Brake Lines on Alston Subframe
- brake bleeders pressure vs suction
- Where did you mount your adjustable prop valve?
- Yet another C5 brake question
- Cambered rear end/brake bracket angle ?
- Wilwood 4-Piston Rears for 12 Bolt.... did it work on a Ford 9"? Anyone done it?
- Some C4 rotor questions
- brake vacum pump
- brembo brakes on 69 camaro?
- 98-02 camaro brakes to S-10 spindles
- Need power booster for MOPAR FAST!!
- 2001 Dodge Dakota R/T 5lug conversion
- Pedal Ratio question
- Best (cheapest?) Source Wilwood brakes
- Wilwood ebrake setup
- line lock ?'s
- Ls1 rear brake conversion?
- Which corvette 13" setup fits on a first gen with torque thrust on it?
- Electric ABS brakes
- Electric Vacum Pump
- Touring Classic score card
- Brake plumbing: 3/16 or 1/4 hard line?
- 60 to zero braking distance
- Wilwood Emergency Brake Cable??
- Help with Baer brakes
- checking brake pressure
- budget hydroboost?
- Brakes for 16 inch wheels
- C5 Master Cylinder Q
- ABS and Traction Control
- full story on converting A-body drums to disc
- 67 nova front disc brakes
- Wilwood Rear Calipers and QA1 Shocks
- 69 Camaro rear disc brake kits
- Swap to manual m/c need help
- rear caliper positioning?
- Front Disc Conversion Kits
- Cheap disc conversions...
- Help Quick!!!
- Wilwood Master Cylinders
- Anyone Get There Baer 6 Pistons Yet????
- HYDRABOOST w/T56 FIREWALL BRACKET?
- 1951 chevy coupe disc brakes
- Brake lines
- Aluminum Hub Kits - corrosion?
- Front Disc Brake Cheap
- Master or Booster?Help!
- which way do the fins go on directional vented C5 rotors?
- MC stroke length question
- What happened to the Italian guy that was..
- question for brake gurus
- C5 REAR Rotor Dimensions
- Larger than stock 68 camaro disc brakes.
- 68 camaro drums to disc
- Rotor rust?
- These will put Wilwood and Baer out of business
- Wheel studs to use?
- 68 Camaro - MC? -->Baer disc/drum rr
- They fit!!!
- Looking for Dimensions of 80's G body rear axle flanges.
- Line lock plumbing ?'s
- Can you use manual master cylinder in power application??
- They DON'T fit (the rears)
- 15/16" bore manual master too much for power C5 brakes
- Hydroboost or manual brakes?
- Disc brakes for 15” wheels.
- Help with master cylinder size?
- Who Makes and Who Sells
- Front Baers Installed
- Aerospace front/ Explorer rear, what MC?
- Hydroboost where to buy
- Christmas in October, Precision Brakes style!
- 13" G-body brakes on the cheap
- Christmas in October Part II
- Changing Brake Pad Problem
- Will C4 12" Rotors Front and LT1 Rears fit my 69 Camaro w/ 15" Rally Wheels?
- 13" 2 piece rotor source
- baer brakes, no need for booster???
- LS1 Brakes complete on 1st gen
- Wilwood brakes problem
- the best rearend to swap under 67 camaro
- More ?'s for 72 chevelle build up!
- Baer's won't lock up
- help with ls1 brakes on a 69 camaro
- Mounting bracket?
- 1970 Cutlass Disc Brake Conversion
- Stainless tube nuts & sleeves, where???
- 4 Wheel Disk's for '67 Chevelle
- Bore Size for Master Cylinders
- late camaro brakes on 9 inch
- Question for the masses on zinc rotor plating..
- C6 Brakes
- Wilwood rear disc brake conversion on `70 Camaro,Problem please HELP?
- g-body C5 master cylinder question?
- hybrid brake setup ??
- My hydroboost install
- 4th Gen rear discs on 2nd gen?
- is it that easy for lt1 rear disk on 79 T/A?
- Brake line question
- pedal does not get stiff
- Thanks To Paul At Hydratech
- Fine tuning pedal feel
- FREE Brake Calculations-PBC
- 67-69 Camaro/Firebird difference?
- Cheap front disc brake upgrade...
- LS1 rear brakes on a Ford 9 inch?
- manual master cylinder for early Ford after 4 wheel disk upgrade?
- Which Big Brake Kit?
- Which Master Cylinder/Booster to run?
- Baer 13" 2 piston
- B-body brakes on a G-body
- Drum brakes on my 65 Corvair
- baer serious street brakes
- LS1 / C5 Calipers - I'm gonna get it right if it kills me
- 2006 ZO6 Brakes feeler thread
- Baer track kit install
- starting from scratch
- Bottles and cans
- LT1 rear disc problem
- Baer Brakes hard pedal?
- C6 caliper Pics
- 4th gen to 1st gen rear disc brakes
- Cold rotors want to lock rear brakes
- C6 z06 REAR brakes?
- Questions about big brakes!!
- Baer Cross Drilled Rotors?
