View Full Version : Automatic Transmissions
Pages : [1] 2 3 4
  1. How to wire up a switch pitch TH-400
  2. What do you know about overdrives!!!!
  3. 700R4 Question - spin wheels out of park
  4. Anybody ever hear of an OD th350?
  5. Have a 4L60E question
  6. B&M Mega Shifter Help
  7. 4l80e tranny installation. How hard?
  8. 200R4-any good?
  9. C-4 Question
  10. 4L60E Basics for my 67 Camaro
  11. 4L60E, 4L80E, or 4L65E
  12. Fluid cooler line help.
  13. Converter POWER!
  14. Th 700
  15. 4L60E shift kit
  16. 700R4 to BG carb
  17. Mating a 96 trans am shifter to a 200r4
  18. Shrifter questions
  19. 4l80e vs. t400+gear vendors
  20. Switch Pitch Transmission
  21. How much bigger is a 4L80E than a 700R4
  22. 4l80e in 69 Nova
  23. Can I replace a 700r4 with a 4l60e?
  24. 4L80E boltup?
  25. Gear Vendors OD and 700R4?
  26. 700R4 reliability questions...
  27. Speedo correction.
  28. Ford AOD
  29. Customized Factory Shifter
  30. Change from PowerGlide to 4L60E
  31. 200-4R lockup or non lockup?
  32. Is my 4L60E in overdrive?
  33. 4L80E info request
  34. TH350 destroyed! Why?
  35. AXOD-E problems
  36. Anyone using Hurst Pro-Matic & 700r4
  37. My 700R4 is toast
  38. Th-350 Problem
  39. Trans gauges
  40. 4l60e vs 4l60r
  41. What is Manumatic Shifting Technology?
  42. 4l80 Crossmember
  43. th350 to a 700r4 ?????
  44. Automatic cooling?
  45. Anyone heard of Gear Star Transmissions?
  46. 4L80e or TH400 w/Gear Vendors in 1st Gen??
  47. shrifter install
  48. fluid change in a 350
  49. stall speed...
  50. what tranny set up should i go with
  51. 200-4R Rebuild
  52. turbo350 2nd-3rd slipping?
  53. best 4L80E?
  54. Tach Wire On Ls1 For Shrifter ?
  55. Cutting Down A Hurst Shifter?
  56. New GM 6 Speed Auto . . . 6L80E!!
  57. 4L80E conversion questions
  58. IDing a 200-4R and a 700R4
  59. General 2004r questions
  60. Vss wiring
  61. 4L80E- where do I look?
  62. BigStuff3/Manumatic Capability
  63. Upgrade the 4L60E or replace?
  64. Question for Steve Chryssos
  65. 4L80E adapter for Pontiac....
  66. Bowtie Overdrives and 4L60E questions.
  67. Universal Paddle Shifter: Ford, Mopar, etc.
  68. i need help with a 700r4
  69. Transmission question for Jody
  70. th350
  71. Dipstick tube differences?
  72. C4 and Stall
  73. has anyone used bowtie OD's trannys?
  74. 700r4 question?
  75. slipping overdrive 4L80
  76. How to pull a pump on a 4l60e
  77. 4L80E and actual gear indication
  78. 200 r4 converter question....
  79. Junk yard hunting. What model for 200R4
  80. which tranny cooler?
  81. AOXD Tranny Problem
  82. Bowtie Overdrives TV kit 700r4
  83. tubular crossmember?
  84. Hurst Pistol Grip Shifter
  85. Mercedes manu-matic
  86. Tci Controller Settings
  87. thread siza on th400 oil lines?
  88. 700R4 No Fourth Gear??
  89. Replacing a powerglide
  90. can I use a 4L60 with a V-8 Small block
  91. 5L40E Swap?
  92. Massive torque w/ 700R4
  93. 4L80E in first gen?
  94. th350 speedo gear question
  95. Mechanical vs Electronic manual shifting
  96. Help pick stall speed.
  97. retro tek push button shifter???
  98. 2004r - Did I hurt it?
  99. Question re: Turbo 400 + GVO fit
  100. Gear Vendors OD vs. 4L80E Transbrake?
  101. Setting up shift points for th350
  102. 4L60e forward clutch assembly.
  103. Horseshoe shifter location?
  104. 4L60E shifting problems.
  105. 200r4 Tranny pan...Which one?!
  106. 700R4 pump question
  107. 200-r4 Vs. 700-R4 Which One?
  108. Art Carr Or Bowtie Overdrives?
  109. Transmission Cooler recommendations
  110. chevy/bop 200r4?
  111. GM 6spd auto
  112. 4L80E behind an Olds 455? - Please Help.
  113. TH350 manual valve body on the street?
  114. Automatic to Manual
  115. BTO 4L80E or 200-4R??
  116. ford aod on a chevy
  117. Temp. sender
  118. Unkown tranny sound!
  119. Best place to buy a 4L80E?
  120. 200R4 Conversion- Crossmember
  121. problem getting into gear TH400
  122. C4 Transmission fluid
  123. lt-1 and 4l60E in a 1969 camaro
  124. Firehawk Transmission Issues! Any ideas!??!
  125. 200r4 vs 700r4 tailshaft question.
  126. 200r4 in 73' Nova
  127. new electronic transmisson to a BOP
  128. 4L60e IN A 1970 CAMARO.....CROSSMEMBER??
  129. Speedo correction calculator
  130. What all do I need to put a 4l60E in my 69 camaro
  131. Anybody running an Art Carr street 2004R ?
  132. Converting a 700R4 from 4X4 to 2WD
  133. Nonpro-touring related 4l80e?
  134. What year 4l60E?
  135. best automatic
  136. Speedo drive gear clip
  137. 4l80e speedo ?
  138. Vaccum fitting..
  139. Auto Trans: How It Works
  140. need crossmember help
  141. Any sellers for the new 6L60 6-speed auto tranny?
  142. To Lock or Not to Lock ... Converter on Blown 383 w/ 200R4
  143. 700R4 Hard 1-2 shift
  144. 200r4 good deal?
  145. Is the 2004r the answer?
  146. i need your opinion
  147. Power glide VS TH400
  148. 4l80e
  149. best place to monitor tranny temp from.
  150. List of stuf for auto swap
  151. Trans guys-Need help!
  152. 4L80E in a 78 - 87 G-Body
  153. G body 4L80-E Swap
  154. Converter ?
  155. torque converter problems
  156. Converter leak
  157. 4L80E modification help
  158. Pontiac 455 + 4L80E = ???
  159. 4L60E best place to buy?
  160. Dip Stick ?
  161. Need ATF Advice
  162. 200-4R troubles.......Need help diagnosing..........Please!
  163. do i really need a shift kit
  164. 2004r vs 4L65e ????????
  165. TH350 Speedo Gear
  166. What Speedo gera do i need?
  167. 4L80e GURU's I have a question for you..
  168. What are these in the pan
  169. 6 bolt flexplate for bbc?
  170. Run engine without tv cable hooked 700r4?
  171. What torque convertor to use 4l60e?
  172. Any Suggestins on Reputable Transmission Vendors?
  173. bell housing bolts
  174. Shifter and tranns cooler Suggestions
  175. retrotec? Automatic Paddle shifter....??
  176. 4L60E no first gear
  177. Replacing a 700R4 with a 4l80E in a 68 Camaro.
  178. Is there a max rpm for the 80E tranny?
  179. TH350 leakage issue
  180. 4L80E software help
  181. Whats a good Auto Tranny for a pontiac 400 engine?
  182. HELP TH400 tailshaft question?..pics included
  183. Mopar 727 sb vs bb
  184. Anyone a Dodge transmmision mechanic?
  185. 307 camaro automatic (X-11)
  186. c5 corvette trans
  187. Trans cooler question
  188. tpi trannys
  189. 4L80E, 74 TA, what to convert?
  190. Which 2004r will live?
  191. 700r4 leak
  192. Eat My Shift
  193. Transmission cooler types and how good are they?
  194. TH700 in a 1980 Z28
  195. trans lines
  196. Ballooning converter??
  197. Filter for a TH 400...
  198. TH350 Dip Stick Tube Seal
  199. 700R4 to 4L60E Swap next week - any pointers?
  200. 4L60E - ls1 or lt1 is there a diff?
  201. Tranny Leak Help
  202. Install a temp gaue with no bug
  203. Best Choice for Mopar 727 swap to Overdrive?
  204. TCI Super Street Fighter
  205. aftermarket th400 pan gasket
  206. id like to upgrade my transmission.. first hand account?
  207. What shifter options
  208. Converter ?
  209. 4L60E AND 4L80E functions
  210. 700r4 converter lock-up
  211. Converter on 385 Fastburn
  212. Swap to from 700R4 to Bowler 4L60E - Running Amazing!!
  213. Bowler Transmission BIG THUMBS UP
  214. 8 Speed Automatic
  215. New style dip stick tube?
  216. Tranny question
  217. 700R4 trouble!
  218. 2 Pair of Pomona Finals Hospitality Tickets For
  219. t56 and Weir hot rod products
  220. 4L80E & paddle shifting
  221. 4l60 transmission builders
  222. Would this be to much undergearing?
  223. Column Shifter to Floor conversion?
  224. 700r4 rebuild
  225. Possible TCC issue with 4l60e transmission. Help needed.
  226. Controller and Harness for 4L60E?...Huh?...What?
  227. Question about 4L80E
  228. B&M shifter cable bracket
  229. Rebuild TH-350
  230. stall speed recommendation??
  231. 4l60e (1996 LT1) - How do I control it?
  232. 6l80e
  233. Anyone identify this 4L60-e VSS for me?
  234. what torque converter to buy
  235. ford c6 stuck in reverse
  236. 4L60e wheel dia increase
  237. Overdrive choices- 4L80E or??
  238. TH400 shifter 2gen-f
  239. th350 park position
  240. installing converter
  241. th400 problem?
  242. 4L65e-will it bolt up to a 406 sbc?
  243. TH400 Question
  244. Q about 2004r full manual valve body
  245. 4l60E strength???
  246. Q how is your automatic setup shifting wise?
  247. turbo400+ gear vendor
  248. 700R4 Shifting question
  249. LS transmission question
  250. c k performance in L.I. N.Y.
