View Full Version : Automatic Transmissions
Pages : 1 2 3 [4] 5
  1. Torque converter for a Th350?
  2. 4l60 bellhousings
  3. Shifter for a 4l80
  4. Help with a part number
  5. trans cooler or not?
  6. C4 going in and out of gear help..
  7. No rotation from 4L60E
  8. Master shift Opinions
  9. 4L80e: no cooler flow
  10. TV cable setup with quick fuel carb....
  11. Compushift TPS calibration problem
  12. split trans bellhousing in half!!!
  13. What Shifter works best for a 6L90e/6L80e?
  14. Need Help Installing Hurst Dual Gate Shifter
  15. bad converter?
  16. TH350 suddenly not shifting - No prior problems. Totally out of nowhere and sudden.
  17. calling all venders!!
  18. 4l65 linkage
  19. Paddles for a stock steering wheel?
  20. Cost to Swap to TH350 or 700R4?
  21. Anyone using the TCI EZ-TCU?
  22. Found some tranny info that ithought you guys mightfind useful,,
  23. Anyone using the Compushift II?
  24. Problem with a 4L80 that no mechanic or automatic transmission tech can fix
  25. Tci controller/paddle shift vs gmppp supermatic
  26. Shiftworks 4 sp auto ratchet shifter
  27. 4l60e no 3rd or 4th gear
  28. Trans cooler...Anyone used something similar to this?
  29. 700R4/ 4L70 questions
  30. 4L65RR-600 Manumatic System???
  31. TH350 Mystery part identification HELP
  32. Broken BEAST sunshell
  33. !!!!turbo 350 problems please help!!!!
  34. monitoring tranny temp more important in a PT car or a drag car
  35. Anyone use 4l80e from early GM 1 ton
  36. Think I cooked my transmission
  37. F-Body transmission cooler???
  38. So I killed my 4L60E...
  39. 4l80e trans need help with setup
  40. 4L60E in limp-home mode...can't figure out why
  41. 700r4 with a blower?
  42. got a free 4L60E trans....
  43. OE Performance - Auto Trans Builder Feedback?
  44. fbody 4l60 dipstick length
  45. 700 r4 speedo conversion
  46. 4TSB from FB Performance?
  47. 4l65 bellhousing what happened?
  48. how much fluid do I need for oil change in 700R4
  49. Engine Dies In Anything But Park 4l80E
  50. Leaky 350 turbo
  51. need help with a stall converter
  52. 4l60e years needed for ls
  53. 200R4 Trans Question
  54. 4L80E Diesel?
  55. looking for a good Tranny builer in Charlotte NC?
  56. 200R4 in a 64-65 F-85, having cross member relocation issues
  57. 4l65 crossmember first gen
  58. Bubbles (border line foam) on Trans dipstick
  59. What OD auto behind a built Twin turbo 383 LT1
  60. Transmission Advice...
  61. Retrotek
  62. What stall speed should I use.
  63. 700R4 or 4L80
  64. trans adaptor
  65. Checking TCC on '93 4L60E
  66. Converter for autocross / road race and cruisng
  67. 4l80e mount to tail housing bolts???????
  68. compushift II
  69. Ls1 5.7 4l60e conversion
  70. 4l60E question .. blowing fuses?
  71. Who makes ATM brand torque converters?
  72. 6l80/90
  73. Lokar locking TH400 dipstick ???
  74. Any opinions on b&m black diamond shifter?
  75. 4L60e Wiring Help Needed
  76. Jetaway to 200R4 coversion
  77. Auto for Autocross/Track Days
  78. What the heck is this?
  79. Crossmember recommendation for 1st gen / 200 4r
  80. looking for hurst dual gate for 4spd
  81. Shifter for 454RFE...HELP..
  82. TH400... For now.
  83. 4L80 in an A body
  84. 2001 Ram 1500 QC 4x2 46 re tans
  85. Manumatic Display at Grand National Roadster Show
  86. Anyone use the Derale cooling transmission pan?
  87. old or new 4L80E? Bolt pattern?
  88. Dual Clutch options?
  89. Transmission fluid flow ? input,output
  90. BMR Releases New Product: Transmission Conversion Crossmembers (TCC005, TCC030)
  91. What size hose should I use?
  92. Has Anyone tried the New Rossler Transmission "little Black Box" ????
  93. Optishift or EZ TCU anyone use them?
  94. 4l60e/4l80e
  95. Need help with 4L70 rebuild options in Arizona
  96. 4l60/4l80 into 2nd gen f-body
  97. Converter choice
  98. 4L60E Builder
  99. Cable or hard linkage shifter??
  100. 4l80e conversion, NEED ADVICE PLEASE!
  101. Will my B&M Mega Shifter work with a 4l80e
  102. Torque Converter Fluid
  103. Best Shifter for 700r4
  104. 700R4 Filter Change
  105. 700R4 Valve Body
  106. 200R4 in a 64-65, trans line routing
  107. Who else other than Keisler makes a kit for 4L65 in a Mopar?
  108. Who is running a 6L90 in an A body?
  109. Chrysler 545 rfe codes
  110. bowler tv cable
  111. Chrysler/Dodge 545RFE has slip
  112. Best price and support
  113. 200-4R lock-up control
  114. 4L60e Out of Impala work in a 98 Z28?
  115. Bump shifters
  116. Sequential vs Paddle shifter
  117. 04 4L80E behind SBC in 85MCSS
  118. Quick disconnects ???
  119. 4l80e flexplate
  120. transmount 1 bolt?
  121. Mad Dog Transmissions
  122. Ford C6 manual
  123. Built 4l60e vs. built 4l80e
  124. High stall converter, sluggish launch?
  125. Paddle shifter help
  126. 700r4 speedo Gear Housing?
  127. 700r4 odd draining problem??
  128. Transmission Advice
  129. Shifter cable routing
  130. Simple Shift install issues
  131. trans suggestions
  132. Trans Dilemma: c4 w/ Gear Vendors OD or 4r70w?
  133. Did i BLOW MY TRANSMISSON UP..4l60e LSX SWAP CUTLASS
  134. Aurora and Northstar V-8 trans
  135. Accu-Link on a Roots blower
  136. 88-72 A-Body w/ 4L series transmission Pan Clearance?
  137. 4L80E rebuild options
  138. Need 4L60E Shifter Cable for 4th Gen Console in 1st Gen Camaro
  139. So Much Frikkin Information...Help!
  140. Acculink Carb TPS
  141. Women to look out to the particular pavements of just about one hundr
  142. 4l60 electronic question
  143. Shifter cable help
  144. kilduff shifter
  145. TH400 cooling
  146. trans not going in any gear nut low.
  147. Who makes tough TH350 Torque Converters?
  148. Th400.....I'm stumped!!
  149. 700r4 not kicking down
  150. Th200r4
  151. 200r4 experiences?
  152. Manual Valve Bodies(TH350)
  153. 4l65e ready for upgrade, but whos qualifoed for a pro touring build?
  154. TH350 Race Overhaul Kits....
  155. c5 vette 4l60 trans, can it be converted to use in my camaro ls swap?
  156. 4L80e shifter suggestions
  157. 6L80 Stand alone trans controller ?
  158. need help with DD tranny
  159. Engine Braking?...or just the right Converter?
  160. G-Body shift indicator linkage won't work with Hooker Comp Headers
  161. 2004R lugs on stops!
  162. Lock Up or Non Lockup??
  163. 68 Camaro 700R swap
  164. 4l80e vs Allison 1000
  165. crossmember sugestions? summit/g-force does not fit.
  166. Trans lines/hoses..what iseveryone running?
  167. PCS push button shifter - is it fast?
  168. LSX/4L60e - Convertor wont match up
  169. Opinions on the 6l80
  170. Suggested 4L60E upgrades ?
  171. Ford Trans.
  172. '06 4L65-e TCC signal?
  173. 6l80e driveshaft yoke
  174. Anyone try the TCI 6X 6speed
  175. 4l80e tranny question
  176. anyone using 4L70E out of TBSS?
  177. Th350 tran not shifting
  178. shifter question 70 camaro ls2 with 4l60e
  179. 74 lemans help me!
  180. '68 El Camino, lumpy high comp. 350 engine, TH400 trans, need TC advice.
  181. 2004R issues !
  182. what carb and tv cable bracket combo? need cheap, easy, and effective
  183. PTCS six speed valve body for 4L80e
  184. torque converter to crank problems, trans/engine already in car.
  185. torque converter wont engage crank
  186. TH400 Not Working
  187. 4l60e ticking noise with speed problem?
  188. 4L65 not engaging
  189. 4l60e shift problem
  190. overdrive trans for big block???
  191. 4L80E early to late conversion
  192. Looking for SFI Bellhousing for 4L80e
  193. I know beaten to death 700r4 converter
  194. 4l60e transmission harness plug-can it be installed backwards?
  195. quicksilver wiring in firebird
  196. 83 700r4
  197. TH350 premature upshift from 1st to 2nd gear
  198. Best place to buy a 4l60e for a reasonable price.
  199. Tranny break-in
  200. 6l80 in 1969 camaro
  201. Shifter linkage shaft - Where to Buy?
  202. Just installed a new 4l60e still slips..pcm problem?
  203. 6L80E with Paddle ShrifterSix Paddle Shift - Success
  204. th350 to 200-4r swap
  205. What to choose, what to pick - for high HP.
  206. 350 turbo Transmission Stall converter
  207. What would make my TH400 do this
  208. installed a 200R4 in my 64 F-85 post car
  209. transmission
  210. 700r in my Oldsmobile
  211. 4l80e to a 350 olds
  212. 700r4
  213. Are all repo camaro th400 lines 5/16 with 1/2-20 fittings?
  214. 6l80 in a second gen camaro?
  215. CTS Shifter for 4l80e?
  216. 4l80e crossmember
  217. gear star transmission
  218. bowler TV Cable
  219. transmission ?
  220. What transmission for stock LS7?
  221. Trans mount 6l80e with AM subframe
  222. 4wd 4l60e or 2wd 4l60e
  223. Transmission clearance
  224. Paddle shifter/ trans controller lag times.
  225. transmission pump
  226. transmission pump
  227. what trans did i just buy? 4l60e? 65?
  228. 4L80E shifter and shift handle 68 Camaro aftermarket console
  229. 68camaro
  230. Ford c6
  231. 4l80e help
  232. 1962 Corvette restomod shifter
  233. 1981 Trans am transmission
  234. 200-4R Secondary Governor Spring Tech
  235. stall size
  236. Need shifter help!
  237. PCS Trans Controller for the van?
  238. 4l60e
  239. Where to find TH400 Vacuum Modulator O-ring?!
  240. Second gen camaro 4l80e crossmemeber?
  241. 10 camaro shifter for a 4l65?
  242. manual 4l80e?
  243. Trans fluid
  244. Hard shift from 1st to 2nd HELP
  245. gear vendor help
  246. 2004r tv cable question
  247. 750hp TH350
  248. 4L60e help
  249. Pontiac 400 trans options
  250. torque converter
