- Low miles sediment in pan
- GV install in 2nd gen?
- Turbo 350 crossmember
- TH400 69 camaro question
- Floor shifter question- truck
- 4l80e
- 4L60E Questions
- Question About TH2004R swap-problem with linkage
- 4L60E transplant in carbureted 68' camaro ?'s
- How much to rebuild a TH350?
- HELP!!! Dieing with transmission issue
- 4L60E rebuild problems
- do you need to remove crossmember to put in transmission?
- Bowtie Overdrive / PDQ converters?
- Cooling a 200-4R ?
- Torque Converter Hits Flexplate Weights! Help Please
- Large or small tailshaft?
- Transmission Cooler Hook-up
- C6 vs FMX
- turbo 350 vs 700r4 vs 2004r?
- Shifter Options
- TH350 yoke and 200-4R the same?
- I need a 200r4 to hold 500hp /450 tq
- 4l80E in a nova...??
- Anyone Help me ID a Auto Transmission in my 69 camaro?
- Anybody running a 4l80e with a PCS controller?
- HP on a stock 4l80e
- 4L80E Question
- Converter lock up question
- Is this going to be a problem?.. some input fellas..
- Gear vendors worth the money
- 200-4R, slipping in and out of lockup at 65mph
- Lost reverse in 200r4 . what happened?
- Trans Temp gauge sender
- Swapping TH400 for an overdrive tranny questions???
- 700r4 decode???
- 4L80e Technical info needed
- What transmission for BBC 598cc?
- speed sensor test
- Drive shaft 2 gen
- th350 won't auto shift
- stock 4l80E
- A clutch instead of a torque converter?
- THM400 Capacity & initial fire up technique
- Stay away from PATC
- 4L80E Conversion Question
- Rebuild/ Replace/ or Convert
- TH350 to 200-4r
- Ford 5R55 limits
- Powerglide weight
- Bowtie Overdrive Stage III 700r4?
- 1969 Camaro + BBC + 4L80-E
- TH350 kick down question
- Cable to use with a 4th gen console
- Strongest Th-350 to go with??
- 700r4 ???
- Anyone make a controller for a 6l80 yet?
- Transmission Guy Needed
- Lockup Wiring??
- Automatic illiterate.
- Help need to buy converter tommorw!!
- 700 r4 questions
- How to make a TH-400 crossmember work for 700R4?
- 200-4r build
- 4L80e date and tail housing identification
- got some 4l60e questions
- 4TSB OD Tranny?
- Best Shift Kit for a TH350?
- 700r4 Install help!!!!!
- Will this 200r4 work?
- I think I toasted my TH350 .............Help Please !
- Fluid change
- trans cooked?
- 4l80E to sbc
- advice on 4l60e builder... PLS Help! must buy soon
- Ford AOD Trans
- Strong OD automatic ?
- 4L60E to Mopar Bigblock, bellhousing or adapter?
- Help!!!!! 700r4
- BOP transmission bolt pattern
- Questions on a swap with a 6L80e
- Lockup of 4L80E before OD
- New TCI TCU #377500 vs PCS
- oil pan 700r4 4l60e
- Torque converter question
- Whats the difference in a T350 and a T400?
- Tci Th200-4r
- 700R4: TCI Constant pressure Valve body
- Auto floor shifter
- Rear engined automatic
- NE1 need a 200R4 from an 86 Monte SS?
- 4l80e to crate ls2 questions
- Alright....I need a convertor.
- TVS cable mount
- Oil recomendation for 95 4l60e
- Trans cooler diagram?
- Anyone ever hear of these guys?
- trans leak
- Which transmission for Edelbrock engine?
- Some help and recommendations
- Speed Sensor Plug for a 700R4
- Overdrive Trans or overdrive add-on
- Th350
- Ovedrive options, auto or stick?
- 4l80E lock up trouble
- need some help on deciding what parts to use
- Trans oil level ?
- Hooking 2000 Camaro SS speedo up a th350???
- 4l80e
- 4L60 vs 4L85e...size??
- Questions about the OPGI 1967-68 His & Hers Shifter Conversion Kit
- Trans disengages while coasting
- looking for info
- Which company to go to for a torque converter?
- Switch Pitch TH400...who is running one??
- TH400 To a carbed 5.3?
- 700R4 converter lock up?
- No upshift on my 200r4
- Problems with Compushift controller
- 4l80 info. needed
- 4l80e brands
- Recomend a shifter for my 4l80e
- Manual Or Automatic
- My tranny doesn't downshift as fast as I'd like.
- Bellhousing to bolt a C5 trans to a LS1 motor?
- changing column shifter to a floor shifter chevelle 350
- 4l80e manual transmission
- Do I have to use a chevelle horse shoe shifter???? need clearification
- Oil change 4l60e - need help - firsttimer
- Need input re: transmission
- Performabuilt Tranny wait time?
- Th350
- 4L80E into 63 Impala ?
- Torqe conveter
- 4L60E tranny
- 4L60E tranny swap problems
- 4L80e and paddle shifter
- Trans mount locations?
- Push button shifting
- TH-400 Gear Vendor unit
- Prep for a new transmission
- Cooling Line question
- Transmission lines to header clearance
- TCI Paddle Shifter
- 700r4?
- Purchase of Paddle Shifter
- 4L80 Question
- Bowler Transmission
- 4L60 TCC Wiring Diagram...
- 4l80 convertor question
- 4l80e Oil Line Fittings
- Electronic speedometer and a 700r4?
- 700r4 Identification Mods
- 4l60 tail shaft conversion
- What causes...
- splines on 700R4
- 4l60e (1996) filter seal removal!
- 4l60e vs. 700R4
- Coming Soon: 4L65RR Manumatic System
- 700r question
- 200-4R Transmission Problems (Any 700R4 gurus?)
- Th200 R4
- what parts to use ona 700r4
- 700r4 direct replacement for TH350?
- Anyone know a good trans shop in MI
- TH350 cooler lines
- T-400 oil change ?
- T-400 modulator
- turbo 400 will it fit?
- Turbo 400/SBC Motor/tranny mount ???
- 4l80e onto 78 sbc
- 200r4 TCC lock up valve---HELP!
- Should I trade?? T-400 for 700R4
- AOD for Pontiac 455?
- 4L80E build parts / model year
- TCI T-Com, 4L/60e, selected gear problem
- Thinking about getting a Bowtie Overdrives 700R4
- What could cause a fresh TH400 to do this?
- Any pcs controller/4l80e tuners out there?
- Rebuilding a 4L60E
- 200r4
- anyone running a 700R4 and using a B&M megashifter??
- Inline 6 and a 700R4
- transmissions with issues non PT related
- Installing a 700r4
- New C4 not engaging
- 4L80E installation in 67 Camaro
- Anyone have a 88 700R4 valvebody installation torque sequence?
- gear vendors + 4l60 + compushift???
- 69 Camaro With 4l60e Shifter Cable Question
- Lokar Shifter Question
- tci tcu
- Trans Cooler
- 4L65E output shaft spline count?
- any experience w/GM X15R 6-speed retrofits?
- Connecting LSX to TH350
- I Want an overdrive trans
- Fitting a 4l80e into a 69 Camaro
- converter lock up problem
- 4L60E problems.
- estimated rebuild $$$
- 700r4 cross member
- 1968 Camaro Automatic Shift Plate Dimensions
- LT1 4L60E being controlled by LSx PCM
- 4l60e Help
- speedometer calibration in Houston area
- Big Block Chevy to 700R4
- 4l60e in 71 camaro?
- I need 700r4/4l60 help
- BigStuff3 Shift Problems
- Neutral Saftey 4L60E?
- 700R4 Line Pressure Port Size
- 700R4 Pressure Test
- Any suggestions on a transmission crossmember (4L60E / BBC)
- 700R4 Build, tough enough?
- PADDLE SHIFT Automatic w/ ENGINE BRAKING - Keisler A-41 for GM & MOPAR
- So guys, my GTOs tranny isnt playing right..
- 4L80E in a '67 convertible f-body
- Ford automatic... suggestions please
- 2009 Transmission Specifications
- 4L80E output port location
- Compushift wiring question
- Who makes
- Electronic Speedo Converter Choices
- 2 speed power glide
- Turbo 350 Kickdown Cable
- Best affordable automatic OD for chevy?
- TH400 filter problem
- New tci 6-speed??
- 4L80E aluminum pan - which one?
- E-Trans Tuning Option?
- Flexplate different for 4L60E?
- 200-4R Car Craft article.
- torque converter bolt torque?
- 4L70E in '64 Tempest, which factory GM dipstick tube?
- 4l60e into '69 Chevelle
- 200-4R shift kit question
- HGM Controller w/ 4L80. Speedo too Fast!
- Big Props to Steve Chryssos
- early shifting aod
- Whining tranny
- 4l60e, shaving in pan question
- Depth of stock pan for 4L80E?
- See Keisler at Super Chevy Baton Rouge 6-8th!
- 6.0 What flex plate do I need
- 700r4 identification and differences?
- Paddle shifters
- Ls7 with an Automatic options with Cruise Control
- B&M Shifter Not Matching Up w/4L60E
- 350 turbo help
