View Full Version : Manual Transmissions
Pages : [1] 2 3 4 5 6 7 8 9 10
  1. Richmond Vs. TKO
  2. T56 input shafts
  3. T56 install into 74 F-body...
  4. resurfacing aluminum flywheel
  5. Where to get a T56 conversion kit
  6. Dial indicator for installing manual trans
  7. Strongest T56 ???
  8. TKO-600 install??
  9. TKO-600 - how do you tighten this bolt??
  10. Richmond ROD shifting woes (from old site)
  11. 4-speed to t56
  12. T56 flywheel
  13. electric speedo and tko 600
  14. tko600 break in
  15. whats a good hyd. throw out bearing kit for tko600?
  16. Shifter for TKO-600
  17. 69 Camaro crossmember for TKO-600
  18. D&D T-56
  19. 6 Speed (T-56) vs. 5 Speed (TKO 600)
  20. Removing T56 throw out bearing.
  21. Trans mount location on viper 6 spd
  22. Z-bar hitting headers, help please....
  23. T56 for a Pontiac
  24. Flywheel
  25. Is there anybody that sell a kit to move the shifter forward on the T56?
  26. TKO-600 clutch adjustment
  27. B&M Ripper shifter
  28. 6 speed clutch setup
  29. Tko 600?
  30. List of linkage parts for 5 speed swap?
  31. Mcleod Street Twin Clutch Too Stiff?? Help!
  32. Tko-600 VS Tko-RR82 600
  33. TKO and mechanical Speedo problems... help
  34. Drive Shaft Installation Issue HELP!
  35. GP on TKO 600 ???
  36. Clutch linkage issue
  37. chevelle hyd. clutch
  38. TKO 600 ?'s
  39. Trying to decide
  40. TKO-600 Shifter
  41. TKO-600 leaks
  42. What is the strongest T56 clutch?
  43. Viper T56 electrical connections
  44. TKO-600 experience?
  45. PN for tko 600...
  46. TKO into a 66' Stang
  47. TKO 600 Break in
  48. T56 build up
  49. T56 kit
  50. T-5 or TKO????
  51. hyd. clutch conversion started
  52. Cartek clutch
  53. Richmond 6 speed or TKO 600
  54. whats gear box do the FAST cars use?
  55. Ls1 T-56 swap...
  56. Auto to Manual
  57. Help adjusting clutch
  58. how about the saginaw 4-speed?
  59. Bellhousing alignment tool.
  60. boot for lakewood bell housing
  61. T-56 Bearing Retainer
  62. Muncie bellhousing (Need quick response!)
  63. Centerforce Dual Friction clutches?
  64. No more Viper t56s?
  65. What is needed to install an lt1 t-56 on a 2-piece seal sbc?
  66. Corvette T56 Calling Teetoe!
  67. 5 Speed MUNCIE ?
  68. Rear End ratio help
  69. Clutchless manual, no electronics, and not a dog box....crazy talk?
  70. What fluid?
  71. Differences between 3.8 T-56 and 5.7 T-56?
  72. RELEASE BEARING help needed fast!!!!!
  73. Tko 600
  74. t56 install questions
  75. Pilot Bearing for a 70 Pontiac V8
  76. Keisler hydraulic clutch kit
  77. t56 swap help needed.
  78. how many quarts..
  79. TKO 600 vs. Rich 6 speed
  80. Modify Trans Tunnel TKO-600?
  81. Cobra t-56
  82. Tranny weights
  83. 74 Pontiac Firebird transmission questions
  84. T-56 flywheel questions.
  85. Saginaw Bellhousing
  86. LS1 T56 vs. LT1 T56 for combination with SBC 383
  87. Reverse switch connector for TKO-600
  88. TKO 600 or T56 ???
  89. TKO 600 or Jerico
  90. Tranny question?
  91. SBC 383 - Need 400 Flywheel for T-56 (LT1)
  92. dimensions for a t-56?
  93. Clutch linkage conversion?
  94. T-56, TKO 600 , Jericho, or what?
  95. T56 Mounting Position
  96. clutch selection
  97. TKO600... offset shifter needed ??
  98. '68 Camaro, T-56 Shifter location
  99. zf six speed hyd clutch??
  100. Clutch arm stroke
  101. What type of flywheel for bb454
  102. Finding T56 Parts (Gears / Shafts)
  103. Throwout bearing
  104. TKO owners
  105. 6-speed for 69 camaro
  106. Correct Muncie Speedo Gear
  107. Bad vibration from the tk0-600?
  108. Richmond 6spd in 2nd Gen?
  109. T-56 hole in tranny tunnel
  110. T56 bellhousing
  111. T-5 worth it or worthless
  112. mule's T56
  113. 5-speed Judge
  114. McLeod Adapter Part # Needed
  115. Whats the difference between a viper t56 and a LT1 t56?
  116. best price on TKO?
  117. TKO Shifters Handles
  118. Tko 500 600 ?
  119. T-56 Pre-86 Block Alternative
  120. Crossmember removal
  121. T56 swap - Driveshaft Mods
  122. LS1 T56 Swap
  123. Need to finalize my shopping list for LS1 T56 swap
  124. Anyone done/seen a tr-3650 swap into a camaro?
  125. Mocking up a T-56
  126. Clutch linkage problems
  127. T-56 matting alternative
  128. Please HELP! Question about hydraulic line
  129. tools
  130. LT1 T56 with Mechanical Clutch
  131. II Much clutch pics
  132. Stupid T56 question...
  133. clutch sugestion
  134. Looking for details on fabbing a t56 crossmember
  135. shifting suggestions?
  136. best prices on TKO-600?
  137. Weight Savings From Auto To Manual
  138. factory ext. bal flywheel?
  139. Th350 Auto To T-56 Swap Cost
  140. anyone used trans-dapt's universal crossmember?
  141. clutch pedal setup
  142. Did It Score On This T-56 Deal?
  143. 4speed ????'s
  144. Torque setting for dual mass flywheel for LT1
  145. Output Shaft/Slip Yoke TKO 600
  146. Hyraulic clutch questions
  147. T-56 Clutch Master Cyl.....HELP!! :)
  148. Mind fart! Tyler..Help!
  149. straight cut, dog engagement?
  150. T56 Clutch/Flywheel suggestions?
  151. Hydraulic Or Manual Linkage
  152. t56 install
  153. What gear ratios are you running with a ...
  154. T-56 Reverse Lockout Bypass
  155. bellhousing mounts
  156. Adaptor Plate For Poncho To T56
  157. TKO install/best clutch
  158. Best th350 to tko600 swap?
  159. T56 in a 69 Camaro
  160. Transmission problem
  161. looking for part numbers
  162. Clutch fork/piviot ball ?
  163. z-bar rebuild kit?
  164. I Need some help
  165. BB Bellcrank nova camaro
  166. 4th gen, strange clutch problem
  167. how close to spec limitations on runout is safe?
  168. TKO 500 for 69 Camaro
  169. Tremec TKO, Shifting problems
  170. adjustable master cyl t56
  171. T-56 rattles
  172. Using Dial Indicator/Magnetic Base
  173. proper (centerforce) clutch break-in?
  174. Mcleod Blowproof Bellhousing Help
  175. tko clutch & pressure plate
  176. TKO speed sensor hookup
  177. Tremec speedo gears
  178. Too high release on clutch pedal??
  179. McLeod B&B/Long clutch?
  180. Richmond 5 spd what is weak??
  181. very slight issue w/tko...
  182. T5 trans questions
  183. Auto to Manual
  184. Belling housing for LS1 t56
  185. need help with T56 install
  186. Which auto to man swap, ATS or Classic?
  187. t56 problems
  188. Can i use this to mock install my T-56??
  189. ID'ing T56's
  190. T56 assembly manual
  191. ZF Corvette tranny in a 1st gen?
  192. Trick Stix,or Pro 5.0?
  193. t56 install questions
  194. How do I identify exactly what tranny I have?
  195. Lt1 T56 Gear ratios
  196. t-56 in a 71 Chevelle??
  197. 4 spd. pedals from 74 nova fit 1st. gen. f-body?
  198. How's my clutch look?
  199. Who's put a T-56 in a Mustang?
  200. TKO 500 or 600?
  201. Which Trans?
  202. Tremec TKO Group Purchase
  203. any way to give a 5 speed some balls?
  204. Flywheel and Clutch Question???
  205. Anybody have this part?
  206. What fluid to use?
  207. t56 in a first gen x chev nova
  208. keisler bell housing
  209. Best tranny fluid for....
  210. matting t-56 to 2 peace seal for under 600.00
  211. Manual Linkage and headers?
  212. Any T56 Rebuilders Out There?
  213. McLeod Clutches
  214. T56 vs. TKO500/600
  215. ATS T56 Firewall bracket/Modified master
  216. tko swap crossmember problem
  217. Flywheel for T-56??
  218. T56 clutch recommendations
  219. BBC -> t56
  220. shifter knob
  221. mechaical clutch linkage to Hyd. throwout bearing
  222. What trans will hold up to high hp?
  223. Keisler TKO 600 vs. ATS T56 Kit
  224. Need a little clutch help, please?
  225. 71 chevelle hyd. clutch question
  226. Selling Tranny, need advise
  227. lakewood adj. pivot ball-help!
  228. T56 Fitting
  229. Muncie 764 Tail Extension
  230. Manual trans pilot bushing
  231. Clutch Start Switch
  232. Tremec Question
  233. LS1/T56 into 1st gen Nova
  234. chevy/viper in a 69
  235. T56 in a 72 chevelle!!
  236. any clutch reccomendations?????
  237. ATS vs. BMR t-56 install kit
  238. best place for a new t-56?
  239. Not P/T related....but a tranny question
  240. Problems shifting to 3rd gear withTKO 500
  241. 502 crate, and TKO600 + 150 shot = ....
  242. Hill Stopper Roll Control?
  243. What Bellhousing to use
  244. TKO 600 shifters
  245. Aluminum flywheel on a t56/t56 in 2nd gen
  246. Need info on Borg Warner SR4
  247. What's "air gap"?
  248. Vibration Problem Tremec and a BBC, Please help
  249. Noisy TKO 600
  250. saginaw info?
