View Full Version : Engine Miscellaneous
Pages :
1
2
3
4
5
6
7
8]
9
10
11
12
13
14
- what ratio roller rockers?
- FP regulator placement
- 305 vs 350 differences
- Another motormount problem...
- One Glowing Header Tube????
- Looking for pics of ls motors...
- '70 Chevelle SS LS6 454 engine specs?
- need help picking cylinder heads chevy 350
- Zz4
- Roller Rocker arm adjustment
- Help me choose an intake manifold/carb
- Vortec heads for a 383
- GM Aluminum Valve Covers
- Need some pontiac cam suggestions
- SBC oil pan removal
- Pontiac 400
- New supercharger, carb question
- looking for deal on autokraft oil pan any help?
- Silly Buick 231 V6 dipstick question..?
- 396 build question
- NRE Motors Tom Nelson?
- SBC Cam Button & Balancer Question
- Serpentine Belt conversion options
- Help me get the drivabeater driving again!
- Water in valve covers?
- Need help with this one...
- anyone got desktop dyno?
- Engine Exhaust - Popping & Crackling
- What gas milage can I expect?
- Terrible vibration
- March serpentine kit PS pump?
- HELP! need discontinued GM pulleys
- LS motor and 6 Speed in a first gen camaro
- Blown 383 SBC or BBC 454???
- Summit Brand Intake Manifolds and Heads
- Streetable Big Block
- Pushrods - when to go larger diameter?
- carbon fiber cold air intake
- American sourced rods and crank?
- Camshaft selection for Supercharged SBC
- Chevy 327
- Opinions needed on power plant
- anyone have experience porting Brodix heads
- SBC cylinder head choice
- How come they dont make Plastic intake manifolds for SBC, SBF etc or do they
- Ford 5.4 Blows Plug from Hole
- LT1 & 6 speed option ..... DRAWBACKS??
- Valve Covers to Fit Procomp Heads?
- New LT1 Head from TFS
- Starter problem
- Street Solid roller lifters vs synthetic oil
- stripped crank snout threads
- Lookin for a swap shop in MD/VA/DE
- Victor JR to HV1000 or AFR intake manifold?
- Automatic Trans on a Mustang Chassis Dyno
- Vacuum adapter that clears carb?
- Ford Modular Engine
- LT1 headers
- brown stain
- Need help choosing head/cam combo
- Eng. torque requierments
- Starting The Engine - Ugh...
- How much is too much $$$
- Lt1?
- Timing, sbc
- 1969 Camaro Z/28 302
- 396 BBC or LT1???
- GM's New Direct Injection V6
- overdrive pulley
- compstar rods and crank.
- 383 Stroker Kits
- Roller cams and Distributor Gears
- 454 bbc
- 400m
- Patriot headers
- stuck off I 95 St Johns county FL
- Compression drop from larger cc heads?
- Need help estimating my hp.
- No Oil pressure on 2001 Explorer 4.0 SOHC
- Can anyone ID this distributor?
- motor/trans mounts -solid or poly? headers?
- PCV and Breather Routing
- Cylinder Head Porting? Where are these guys at?
- air/fuel monitoring
- 327 build help.
- tranny oil in engine
- Engine Questions!
- New Dart Ford block
- Fuel filter question.
- Should I go 383?
- Composite lifters
- Jet size for mighty demon 750
- Need a lot of help with engine mounting.
- Need help with future motor project for (road racing, auto-cross)
- Engine Ideas
- 406 SBC high rpm build
- degreasing an engine on the stand
- Timing Setting
- 318hp ZZ4 ?
- Short or long water pump
- Copper head gaskets
- initial engine start
- Dry sump plumbing question
- opinions on summit racing/patriot sbc heads??
- oversized heli-coils?
- Hydraulic roller cam and head questions.
- Do I have motor/transmission mount options?
- 351 Cleveland
- Engine Weight
- traditional pontiac aluminum oil pans
- 383-406
- Hey Ford Guys....
- Foamy filters
- Lower engine
- Spark Plugs for Chevy Gen1 Prochager engine
- 90 Accord will not start
- camel hump heads max lift
- Cam idle and performance????
- Deep Skirt Reinforced Oil Pan
- Adjusting Valve Lash Order?
- Interesting engine concept...
- Fuel pump pushrod?
- 6.1 SRT8 Hemi Engines New In Crate Just trying to help!
- cam question
- Engine misfires
- any one got ideas for a 360 f.e.?
- Don't tell them it's a project
- PCV & brake check valve-share?
- Plug Gap Question
- For the LT1 experts... safe to remove coolant line from back of heads?
- Out of Paint after two years preparation for starting???
- Oil pan removal in a '68 Camaro
- Anybody Ever Use a Milodon Road Race Oil Pan?
- anyone have a cam like this??
- professional products intake manifolds
- thread size vacuum port edelbrock manifold
- Combustion Chamber cc'S
- 04 ford taurus rev limiter problem
- starter, difference between manual or automatic?
- PRW Stainless Rockers ?
- Engine Stands.... What are you using?
- BBC rockers hitting valve covers?
- Best top end set up for SBC 350
- DIY Engine Coatings
- BBC main studs vs. bolts
- Black -AN Valve Cover Breather
- March crank pulley question.
- Fuel Injected Supercharged Gen 1 SBC kit from Eaton?
- 91 Trans Am GTA - Starts / Idles / Dies with gas
- 502 heads on 454??
- Pontiac 455 balancer?
- Good Centerbolt Valve Covers
- vortec fuel pump
- anybody ever use the twisted heads 340cc for a bbc
- Starting issues
- Engine Advice for 70 Camaro - 383 or Big Block
- vortec install
- Chevy 305 questions
- oil pressure jumping around alot.
- Crankshaft Failure
- Camshaft lobe appearance HELP!?
- March Performance - Be careful
- Engine Paint
- Starting motor (power steering pump)
- MSD coil question
- Cometic Head Gasket Leaks?
- No more loose valve cover breathers
- Governor on 1996 Chevy Silverado
- strong fuel smell
- DSE Windshield Wiper Motor
- Bypass Filter kit, Amsoil - Anyone use/comments?
- Engine Mount question G-Body to A-Body?
- amyone here running an LT1
- gasket
- 572 turnkey motor
- TFS - Twisted Wedge SBC Head question
- good roller cam for BBC
- Gas tank pressure?
- Ram Air/Cold Air Theory
- sbc rockers & guide plate question
- I GUESS fuel delivery problem question??
- Rocker and ball question
- chevy crank length problem?
- 502 Ram Jet - Install help
- Where do these gauge senders go?
- SBF Roller Lifter Cam Selection
- Crane specs?
- Short fabricated SBC Valve Covers needed
- help with idle problem TBI camaro!
- Pontiac Stroker
- anyone running trickflow heads on SBC?
- 427 corrected - yikes, this car is HOT!
- Chevy Engine Build
- Anyone know anything about the composite timing covers on vortec motors?
- pushrod length
- Fastburn 385
- starter seems to jam
- Pontiac 389 inital timing
- motor not going in
- Help with cam selection
- rebuild my 396 or build a 454
- Fast burn 385
- PCV? or no PCV?
- How much does it weigh?
- Dart Machine to build LT1 blocks
- Nascar SB2 Engine
- Trying to decide on an engine for my '69 firebird street car
- Chevy R07 Parts
- Oil Questions
- Remote oil filter?
- need help on 454 engine build
- 1st gen camaro power steering upgrade
- Questions on Big Block swap for first gen
- Merlin 540 oil consumption or wierd level readings!
- hp guess?
- Huge Engine Weights List
- Best engine oil
- Dart Pro-1 215's
- BBC: Is this a crossover thing, or do I have problems?
- Dipstick
- High compression, small cam
- SBC mounting location in 2nd gen
- 632 BBC Motor
- 502 assembley questions.
- the max power for a ford mod motor?
- Engine Vibration :(((
- 406 Build...Advice Please!!
- 383 gas milage help.
- 2nd gen Motor mount nightmare!!
- LT1 to 65 skylark, need help
- what gasket material?
- Need an Engine for a Mark VIII
- Degreeing my cam, is this close enough?
- Big block valve covers breathers/baffles?
- BBC cam install
- Good 2nd gen headers with SBC
- p/s bracket
- power steering pump mountiac pontiac 455??
- Thumping noise
- LS1 2 Be
- Auto Meter plumbing locations
- 70's Camaro Engine Help
- Oil Control
- lt1 head Cast vs Al?
- welding an oil pan??
- Piss power
- Crate engine for a 2nd gen camaro
- Lt1 or ls1
- Buick V6 Question...
- massive vacuum leak
