View Full Version : Heating & Air Conditioning
Pages : 1 [2] 3
  1. Vintage Air 4 knob gen II streamline panel
  2. Heater core or not?
  3. 69 Firebird Vintage A/C
  4. Attn Pontiac owners, what crank pulley for A/C?
  5. AC smells
  6. Pros/cons of Gilmer pulleys?
  7. 12 volt heater valve?
  8. LS1 ac compressor bracket
  9. VA, routing hoses other than thru blower hole?
  10. Anyone familiar with nostalgicairparts.com?
  11. Pontiacs with Vintage Air, heater nipple on head or intake?
  12. GM R4 compressor in serpentine acc. kit come with or w/o oil?
  13. Question on DSE Compac AC Bracket for 69 Camaro
  14. Vintage air... what do most folks do?
  15. Someone was looking for some factory style AC dash vents
  16. Who makes/sells a front drive system
  17. Sanden compressor mounts/GTO-LS2
  18. ATS plates and low mount AC..
  19. AC Clutch Squealing
  20. AC Box Drain Design
  21. Vintage Air issue
  22. not running a/c, should i remove unit under hood?
  23. Swage Fitting Leaking / Vintage Air / Need Help
  24. Glue for plastic heater box repair?
  25. AC question
  26. A/C System Not Holding Vacuum When Evacuated
  27. Problem with AC on full size Chevy truck, need thoughts..?
  28. vintage air will not turn off
  29. compressor 10s17f variable or fixed
  30. 1967 nova a/c pictures
  31. Vintage air install questions/help - 70' Chevelle
  32. Mounting my 69 Camaro Vintage Air unit
  33. 02 Camaro AC
  34. Intermittant A/C operation.
  35. Thin ductwork??
  36. Vintage Air ?
  37. Hot Road Air
  38. Best AC system for a hacked 68 Firebird?
  39. Vintage Air v. Classic Air
  40. Rear Air
  41. orfice tube
  42. Kwik Performance ac bracket LS1
  43. Recomendations on aftermarket A/C Kit
  44. r12 manifold conversion
  45. Adjusting the A/C Cycle Switch on a G Body Monte Carlo SS
  46. Should I go OEM or A/M air conditioning?????
  47. Adjusting Idle after installing Vintage Air
  48. Vintage air? Good/bad? Options
  49. Options for custom AC vents???
  50. Convert Superheat to Non-Superheat, Benefits?
  51. Show us your aftermarket a/c vents/louvers
  52. Adding a lower Front Spoiler
  53. Heater cables
  54. Vent delete cowl panel work with AC?
  55. Vintage air 68 camaro questions
  56. VA Heater delete plate
  57. 72 Lemans removal of factory A/C
  58. OEM cooling fan to use instead of a SPAL dual 12" setup?
  59. march serpentine belt
  60. Vintage Air Install - Help Needed
  61. Cutting rubber AC lines
  62. Dex-cool ....Is it good or bad??
  63. factory ac box cover
  64. LS1 PCM and Vintage air?
  65. LS factory AC compressor question
  66. Electric Fan Option
  67. 70 mustang heater box, can i get anything smaller
  68. 67 Camaro non-Ac dash questions
  69. vintage air or hotrod air who u like
  70. Kwik Performance Bracket - Install Help
  71. Detroit Speed Heater Delete Plate
  72. Vintage Air Compressor Bracket
  73. Fresh air ventilation with Vintage Air
  74. Wire Adapter?
  75. 'Mojave' type heater under dash?
  76. High Mount AC Options for LS
  77. Sanden 508
  78. pusher fan
  79. really small AC compressor
  80. Testing VA Setup
  81. LT1 Compressor Hose Routing
  82. Heater hose fitting on LS1
  83. AC swaps?
  84. Sealing inside of doors before sound deadener / insulation.
  85. Help, how do I remove the blower assembly in a '68 Firebird?
  86. 1967 Mustang with Magnum air?
  87. Vintage Air Bulkheads lets see 'em
  88. need help identifying a compressor
  89. Controlling the fan with GMPP ECU
  90. Losing my mind; Can't keep it cool...
  91. Need my electric fan to turn on when AC is on?
  92. A/C condensation problem
  93. kwik braket
  94. ac mounting braket on iron block LS2
  95. 2nd Gen T/A lsx A/c
  96. any first gen f-bodys running heat with ls swap
  97. AC not working on High Setting
  98. Gen IV vintage air controls
  99. vintage air?
  100. Mastercool flare kit needed
  101. Anyone know of any sales/discounts on Vintage Air kits?
  102. Vintage Air Gen IV install in 78 LS1 TA
  103. vintage air help needed
  104. stock 81 camaro A/C problems
  105. Burning up Compressor Clutch
  106. Accel Thruster EFI + Electric Fans + A/C question
  107. Building a 64 Olds F-85 "rustbucket"
  108. Vintage air problem
  109. First ride with Vintage Air!!!
  110. What should I get for a/c ???
  111. '72 Buick GS with Vintage Air
  112. A/C fittings
  113. Sweatin holes in my underwear!!
  114. Pics of Vintage Air Condenser/Drier
  115. Heat/Air Blower Motor Upgrade for 1987 GMC Truck
  116. Leaking water from under glove compartment area..
  117. 69 camaro w/vintage air drain pipe suggestions
  118. Is it possible to convert a non-factory ac car to a factory ac car?
  119. Vintage Air Dealers?
  120. Changing pulley on my SD7
  121. Calling people that have installed a Vintage Air System
  122. Vintage Air 3 knob controls
  123. What's the difference in these Sanden AC compressors?
  124. Mounting a Vintage Air Mini Gen II behind seat, thermostat capillary tube question
  125. Anyone running vintage air in a 1970 mustang?
  126. Any one ever convert a Chevelle from POA valve to orifice
  127. Vapor from defrost vent after changing heater core. No coolant leak or smell.
  128. Condenser Hard Lines for Vintage Air Front Runner
  129. Gen IV calibration mode
  130. Vintage Air gen IV problem...
  131. Tell me about your Gen IV system
  132. VA Magnum dimensions?
  133. Need Vintage Air for 1966 Nova...were to buy?
  134. 69 Camaro heater control assembly
  135. Name this part!
  136. Need help finding an A/C hose fitting
  137. heater delete...but still need heat.
  138. Vintage Air GenIV questions
  139. You know what I want to see?
  140. 68 camaro/firebird astro vent kit aftermarket?
  141. 63 Nova factory under dash unit
  142. 1959 1960 impala AC heater kit????????????????
  143. AC compressor poll,,,,,,,,,,,
  144. 69 Camaro LT1 swap - Want to add AC
  145. Best air cond. kit and pully system?
  146. First gen Camaro HVAC (NOT OE or Vintage Air)
  147. Gen 5?
  148. vintage air gen IV main power
  149. Mounting compressor low on 2nd gen camaro
  150. Question on Vintage Air streamline 3 knob controller
  151. Another VA bulkhead ? 4 Inline or diamond/square?
  152. How much HP loss from VA IV AC?
  153. ac kits
  154. Even more Vintage Air Gen IV questions...
  155. Best price on Vintage Air?
  156. A/C question LS2 69 camaro
  157. Vintage Air Heater Control Valve...Extremely Hot....HELP
  158. Air Conditioned Seats (Heated and Cooled)
  159. Has anyone ever done this before vintage ac with a blower motor
  160. How difficult is it to install Vintage Air Gen IV in F- Body?
  161. 2012 Camaro LFX V6 AC compressor type?
  162. vintage air.
  163. Restomod Air
  164. ctsv a/c compressor
  165. Sanden 508 Compressor Question
  166. what compressor with a LS3 and factory 80's GM AC??
  167. LSX engine/Sanden compressor in a Factory AC second gen. Anybody done this?
  168. Vintage Air U Bend It AC hard lines
  169. Dual zone climate control
  170. Vintage Air Gen IV - where did you mount your relays and circuit breaker?
  171. 77-2nd Gen Firebird A/C
  172. A few general vintage Ac questions before purchase
  173. Could someone identify this part?
  174. stv conversion
  175. Sanden Compressor Manifold
  176. heater lines on a LS3
  177. Modern donor vehicle for 72 Chevelle AC
  178. smooth firewall with ac
  179. Sanden SD-7 Compressor Fittings
  180. Running VA AC line through blower motor hole
  181. Reduced Diameter AC Lines
  182. Testing A/C
  183. Tearing down car-what about AC unit
  184. 68 camaro vintage air question???
  185. Electric water pump plumbing for interior heat and defrost
  186. Vintage Air price increases JANUARY 1st - Get your kit before!!
  187. Shor vs long water pump ?
  188. AutoRad opinion
  189. 69 Camaro Vintage air through the heater hole
  190. Vintage Air Gen IV recirc/fresh air door
  191. Vintage Air Blend Door Problem
  192. Rear defogger for 67 Fastback ideas?
  193. Which aftermarket AC, Vintage or Classic?
  194. Aeroquip Performance Catalog?
  195. Impala AC Problem
  196. Help with Vintage air problem.
  197. Aluminum AC Hard Lines
  198. Reduced Diameter AC Hose fittings
  199. Powder coated or painted ac compressor?
  200. DSE Bolt in delete plate
  201. Vintage Air Gen 4 67 camaro
  202. Front and Rear System
  203. Vintage Air heater control valve
  204. factory air conditioning on '69 camaro
  205. 67 Cutlass, new or restore?
  206. Vintage Air heater control valve not working?
  207. Can't believe I did This!!!!!
  208. Compressor fittings for Sanden SD& compressor?
  209. Vintage Air Gen IV blower issue
  210. what bracket for low mount
  211. Racing Product Company Bulkhead
  212. vinage air heater hoses?
  213. Auto Rad in a 67 - 69 Camaro
  214. 71 Camaro A/C Delete Box...
  215. vintage air in a g body
  216. Aftermarket HVAC controls
  217. Vintage Air wiring
  218. First Gen Vintage air case controller options!
  219. (Partial) A/C kits -under dash
  220. Running AC Drain Line
  221. 1968 Camaro Stock A/C with LS motor
  222. Restomod Air Review??
  223. Condenser placement
  224. Vintage air or classic air??what should I get??
  225. Vintage Air Heater fittings,
  226. Vintage Air for a '53 panel truck..help?!
  227. Need help with v/a problem..tech no help.
  228. AC system for 64 F-85 pro touring build
  229. Welding Aluminum AC Lines
  230. 86 Monte with 2008 LS2, Air conditioning help please.....
  231. PRC Core Support/Radiator/Condenser--How to mount Drier?
  232. AC lines for tight radius
  233. Which vent is which? Heat/Def only system - '68 Camaro
  234. Will Aluminum AC Hard Lines Sweat inside car?
  235. Hot Rod Air evap wiring
  236. Vintage Air blower / fan won't shut off
  237. Vintage Air with LS Compressor??
  238. Heater with billet controls? Mustang 1971-1973
  239. 69 non ac camaro with a vintage a/c for a camaro with a/c ..will it work
  240. A/C bulkhead
  241. EZ clip A/C service port fitting hunt.
  242. Vintage air with Auto trans coolers
  243. Kick panel air vents
  244. Radiator question
  245. Need help with cooling system wiring (Dakota Digital Fan Controller & Vintage Air)
  246. A/C Hardlines
  247. Pics with CCA kit installed on a 1st gen f body?
  248. VA Gen IV in out question
  249. gen 4vintige air rear bracket for smoothed fire wall
  250. AC lines anyone have a source for these?
