View Full Version : For Sale - Parts
- 1970-81 Camaro Steering Components
- 2009 6.0 and 6l90e 2wd
- Not my CL ad - 1968-1969 Camaro Detroit Speed Suspension - $6800 (Houston)
- (2) MICHELIN Pilot Sport 335-30-ZR18 Very Meaty Tires (used)
- Detroit Speed 2nd Gen F-body front suspension parts for sale (NEW)
- FS CCP front spindles for second gen
- FS Pypes 3" stainless exhaust system 2nd gen f-body, stainless, chrome 3" T/A spliter
- Baer 14 inch rotors for sale
- Wilwood Superlite 6 brake kit for M-II
- Misc & LSX parts for sale!
- Twist Machine Muscle Drive Converter 4L80E
- Cobra Monaco Seat
- Hyperco/Ridetech Coilover Springs
- Quicktime Bell 6023-PB Ls3 Corvette Oil Pan (New) Hypertech Thermostat 160 & 180
- GM LS Engine Throttle Pedal Controller, NEW
- Hotchkis 3" lowing leafs, bilstien shocks, Hotckis rear sway bar - FS
- Wilwood/Global West/Quicktime/Autometer FS
- *wtt/wts:5.3 truck parts, lg G6X3 cam,ls3 heads, holley 830cfm carb
- richmond gear super T-10 4spd
- FS - LS3 intake, rail, injectors and throttle body (Ported)
- Gauging interest in rear C6Z06 setup.
- 17"Mickey Thompson ET Street Radials
- Auto Meter Sport-Comp Speedometer
- 67-69 Camaro/Firebird Global West complete suspension setup w/ QA1s
- Left Over 69 Camaro Parts
- BFG KDW 20's - on Craigslist
- 1957-2005 AMC/GM/Ford/Mopa etc Billet Tie Rod Sleeves
- 1lE PBR Corvette, Camaro, Trans Am Front and Rear Calipers
- 1968 Camaro Fiberglass Inner Fenders (pair)
- Rickmond 6 speed
- Holley 1850-2 600 carb
- 66 chevelle seats
- NEW Un-used LPW 12 Bolt GM Diff Cover
- NEW Un-used Street & Performance Polished Alloy Parts
- FS: black c6 Z06 seats
- Tr6060 low miles trans
- Guaging interest: F/S in NY Chevy 350/330hp with 650 edelbrock 3k obo or LS trade neg
- DSE 2nd gen Camaro / Firebird New Parts - MUST SELL EVERYTHING!!!
- 2011 6l90e for sale near OKC
- 1967 1968 Camaro Front Fenders - Need Work - Los Angeles
- LS Oil Pan & Corvette LS3 Accy Drive Bracket
- Holley 0-80555C spreadbore carb
- 1st gen Camaro Quarter Window - Drivers side
- FS-1967-69 Camaro Twist Machine brushed core support bars
- LS1 241 heads complete $125 Shipped TTL48
- 1ST GEN CAMARO ATS adjustable trans crossmember
- T56 Maganum white Lighting shifter
- Flowmaster 3" tailpipes
- 12/200 Varisprings
- Muncie M21 Close Ratio 4 Spd
- TKO600 Shifter, 5 Spd Knob
- lots of parts 1969 camaro dse,t56,hre....ect
- Various 6.0 Vortec/LS Parts
- Borg Warner Super t-10 4 speed in OKC
- *Corvette dry sump oil tank
- Team III Minilites
- Parts for sale
- foresight ventures magnesium wheels
- Sparco Torino Seats
- Parting 1981Z28
- FS: LS1 F-body oil pan/pickup tube/dipstick
- Brand New 275/35/18 Falken RT-615K tires 200 treadware and Sticky!
- *** PAIR Of Procar Sportsman Pro Seats by Scat ***
- Dakota Digital VFD3 Guages for 69-76 Nova
- *** PAIR Of 1968 Camaro Original Seats, CLEAN Newer Uphostery ***
- 11" Delco Booster for sale
- Detroit Speed Mini Tub Kit Less the Tubs 68-74 Nova 67-69 F-Body
- 20" 6 Lug HRE wheels new Goodyear 285/50/20 So. Cal only
- 383 stroker
- LS Swap Parts!
- C5/C6 Corvette Rear Disc brakes w/ Kore3 10/12 bolt brackets
- gm rear disc brake kit, stock $125.00
- Magnaflow Catalytic Converters
- '77 T/A 8.5 3.73 Posi Rear
- FS: thunder rd classic dash panel 69-76 nova
- 1997-2004 Corvette Calipers (NEW)
- Viper T-56 Transmission
- Eddie Motorsports Machined Pedal Covers 68 Camaro manual 2011 Camaro dbw gas pedal
- FIKSE PROFIL 5 rims with Michelin Pilot rubber
- judging intrest Baer Brakes Baer claw track kit
- Bell housing
- 2ND Gen F body LS Swap headers, Global West Springs, G-Force x-member.
- LS6 Intake manifolds bare and completes
- LS2 with Zero miles... Never installed
- Chrysler 8 bolt Ram flywheel and clutch
- 604 BBC 734hp 738 torque
- 69 camaro tilt column, shaved key with high beams on turn lever 400.00 30.00 shipping
- Boze Lateral G Forged 17" Wheels w/ Nitto ZR Radials (Complete Set of 4)
- 18x9/18x10 Bonspeed Huntington's w/Nitto NT555 rubber for sale...!
- )9 Camaro rear axle
- 68 firebird driver's side oer fender-new
- 2nd gen camaro front suspension
- LS Swap Parts!!!
- Shiftworks Mechancal Speedo Tail Housing for 4L60/65/70
- Ridetech a-arms, shockwaves and spindles for F-body
- 70s seats
- Feeler: Wilwood super lite 4r for big ford new style housing
- LS1 Front and rear brakes for sale
- Lee remote P power steering pump
- LSx 415 stroker kit
- A few bits and pieces...
- 70-81 camaro/firebird tubs
- FS: Ridetech Tru Turn w/ drop spindles for 69 camaro
- FS: Ten Factory Axles Ford 8.8
- Powered buckets new uplholstery and push to start system in So Cal
- Ridetech Spindles 1st Gen F Body Camaro/Firebird and Nova
- Gm Richmond 5 Speed with Hurst Shifter, BOP Bellhousing, Pontiac Flywheel/Clutch
- 67-69 Camaro/Firebird and 68-72 nova Subframe
- 10 Bolt 8.5" Rear Axle Housing / Axles / Posi out of a 1973 Camaro Z28
- FS: New Vintage Wheel Works V40's w/ Tires
- New Bilstein B6 rear shocks 3rd gen f body
- 1967 GM A-body 1" Hotchkis Springs
- 1st Gen Camaro Firebird ATS spindles
- Afco Spun Aluminum Air Cleaner Base with K/n Filter, Powdercoated Matte Black. NEW
- Hydratech Hydraboost Unit, as shown
- 68 Chevelle Aluminum gas tank
- Global West upper and lower control arms and bracket for new coilover for a body
- MSD Atomic EfI Master kit and FAST EZ EFI both new demo kits
- 17"Budnik wheels
- March 1 pulley setup sb chevy
- GMP Diecast for sale
- 1969-1974 Nova Anvil Carbon Fiber Dash Insert and Closeout Panel
- New Summit Racing Digital Ignition Box
- Craigslist Find: 2012 5.0 Coyote w/ trans
- Detroit Speed Parts & 68 Camaro RS Conversion Kit for Sale
- Parts take off...
- 40lb fuel injectors
- Edelbrock Victor Series Aluminum Water Pump - New
- Holley 4150/750/80779 double pumper carb
- *4 piston Brembo brake calipers
- Gen 1 TMI Houndstooth Sport Seats
- Misc. LSx parts
- Misc. parts
- Budnik Ice Rims
- 18" Budnik Wheels
- Rear suspension parts
- LS timing chain, gears, oil pump
- LS T56 Hydraulic Clutch Line - Quick Disconnect
- Fesler Brushed '69 Camaro Hood Hinges - Darn near new
- Ridetech Coilovers for 1st Gen Camaro
- FTI Torque Converter 4L60/65/70
- Belltech 5100 1.5" Drop rear springs G body
- KDW's for sale, full set.
- Cheap 200 Treadwear Autocross Tires!
- Borgeson Polished Stainless DD/DD Steering Joint, Coupler NEW
- Steering Wheel
- 1st gen Wayne Due subframe
- Anvil Carbon Fiber inner fenders 69 Camaro
- NIB Wilwood 12.19" 2 pc drilled rear brake 4 piston calipers for 1st gen F-Body
- L92 truck intake
- 21" 5th Gen Camaro Rims
- LT1 to T56 bellhousing
- GMR BILLET Front C5/6 Hubs
- GMR Billet Rear Full Floater Hubs
- GMR FABRICATED Steel C5/6 Uprights
- GMR Chromolly Fabricated 9" Housing
- c5 brakes for 2nd gen f body, spc adjustable upper control arms and ls1 harness and s
- Temperary project wheels to roll your project around
- Pro Systems Carburetor
- **For Sale New 67-69 Camaro Scott Mock Subframe**
- **FS New LS1 Level IV RPM transmissions with BellHousing**
- **FS 67-69 Camaro DSE Quadra link and 9"rear end set up**
- **FS AutoRad 67-69 Camaro core support only**
- PSI Conversion Harness LS2 24X T56 DBW Includes Pedal, TAC, and PCM!!!
- FS - Multiple Sets of 275/35/18 Tires
- (MA) Kore3 braided stainless brake lines
- Jags That Run & Dakota Digital VSS Speed sensors Pulse Generators FS
- Ready to assemble olds 455 block, storker crank, oliver rods
- Billet Intake for Ford 4.6L 4V 'C' heads
- CPP 3" Rear Lowering Springs - 67-72 Chevelle
- March one pulley sb chevy
- Bb hooker headers
- Fresh Small Block w/ 700R4
- Aeromotive A-1000
- New Holley / Weiand LS Polished Intake 300-111P
- Fidanza aluminum flywheel small block or big block chevy
- 2.9 Whipple Polished Complete Installed For Mock Up...
- FS Global West LCA GM A body
- FOOSE LEgend Rims/ with Tires
- Boze Friction polished and cleared 18/8 x 18/10 Brand new in Box
- SPC Performance Springs-`68 -`72 GM A body
- DSE parts and garage clean out. All parts are new and have pics if needed.
- 1967-69 Camaro / Firebird parts
- 12 Bolt Rear End With Factory Posi Uit
- LS1 rear disc brakes for sale
- 1st gen Ridetech arms & spindles| Hotchkis swaybar
- Parts!
- A/F/X Power Disc Brake Swap (Stock)
- **FS New Autokraft Oil Pan**
- **FS New Polished LS Accessory Drive Kit**
- **FS LS3 Intake Manifold, Polished TB,Black Holley Fuel Rails and injectors**
- **FS New Katech Valve Covers**
- complete Eagle 496 balanced rotating assembly
- C5 Brake Booster and Master Cylinder
- Rushforth Rated-X Wheels and tires
- **FS LS2,LS3,LS7 (8) Coils with Brackets and Harness**
- **FS New JEGS Proportioning Valve**
- Moser center section
- Dougs D306 BBC Headers
- Polished Weiand 177 Supercharger
- qa1 shocks, holley 750dp, arp head studs pre 04, heat sink coil packs much more
- 540BBC and components.
- FS Vintage Air, Ring Brothers, Quicktime
- ATS Tall Spindles 1967-69 Camaro Brand New
- LS conversion engine mounts
- Books for sale...
- 6 tilt columns, 69 camaro/firebird,70-77 camaro/firebird
- Tremec 5 Speed Shifter Knob Brushed
- Coys c57
- 67-69 Chris Alston 8 point exact fit till cage
- First Gen Tubular A arms
- Billet Specialties 14" Split spoke steering wheel
- Fox Body Mustang/5.0 Part-Out: It's all new!
- sparco steering wheel & adapter
- NIB Meziere remote water pump and accessories for LS
- QA1 Rear Shocks Used 67-69 Camaro
- Lokar Floor Mount Emergency Brake Cables EC-81FU
- Budnik Black GTO Steering Wheel and Chevy Hub
- Mcleod Flywhell, Clutch, & Pressure Plate- T56, Gen 1 smallblock w/ 2pc rear seal
- SC&C G Body Chassis Brace
- Custom Gas tank built to your specs
- Brand New 67-68 Camaro Wire Harness and 67 RS Harness
- 88-96 C4 Dana 44 Chevy Corvette IRS rear suspension. Seattle, WA area
- 245/45 17 & 335/35 17 michelin pilot sport tires
- Be Cool Universal Electric Fan Module Mounting Brackets 72038
- ATS adjustable crossmember 67-69 F body and 68-74 X body
- CTSV Brembo Brakes front and rear complete setup 1000.00>
- 68-69 camaro weatherstrip
- Brake adjustable proportioning valve combo block
- Schwartz Performance gift certificate
- 28 Spline 9" Ford Detroit Locker
- Schwartz Performance Chassis
- Billet quick release fire extinguisher clamp
- LS2 corvette harness
- Not mine - Ran across a 390" AMC Hurst SC Rambler Engine for sale
- 67 - 69 Camaro Parts for Sale (Radiator, LS Water Pump, Power Windows . . . etc)
- 1970 nova subframe and suspension parts
- Devilbiss JGA-502 pressure/siphon feed spray gun
- Baer Brake front brake kit (4301443S - SS4 Plus 11 inch Rotor) $1150
- 90 mm - ls series throttle body for 4-bolt intakes
- Tci 700r4
- New Falken RT615K 275/35/18 $199!
- rod end adj rear control arms for 68-72 A body
- Cammed LQ4 long block ky
- B&M Shift Improver Kit for TH400
- DSE Subframe Engine Mounts 1.5" Set back
- Ridetech Tru-Turn complete package never used
- Hella 7" H4 Headlight Housings and High-Power Bulbs
- New bfg kdw 335/30/18
